Upgrading non-bose stereo in 09 Cayenne GTS?
Going to look at an 09 Cayenne GTS which has PCM w/ Navi but no Bose. How bad is the non-bose stereo and is it possible to add an amp and upgrade the speakers while keeping the PCM without too much trouble?
Thanks in advance!
Thanks in advance!
I have been looking into doing the same on our '06 with Nav and non-bose. What I have found is that it really depends on what you are attempting to get out of it. Do you want something that is just a little bit better dynamic range or do you want something that is loud and has good clean tight bass? I would find a good local car audio shop... don't go to Best Buy or the like... and ask them what your options are. The speaker locations are fairly difficult to get to and behind some expensive and frustrating trim panels... unless you have a lot of experience with car audio install I would not recommend a DIY. A good car audio shop should be able to identify what you need and work within you budget for a solution.
No one else has done this on an 09-10?
Thanks!
the AudioControl LC8i is a good example
PelicanParts.com
08-26-2015 04:25 PM
PelicanParts.com
08-26-2015 04:24 PM
PelicanParts.com
08-20-2015 02:57 PM
