DIY clear corner mod
Old 04-15-2012 | 09:13 AM
bigdog's Avatar
bigdog is infamous around these parts
Hey guys , I'm on the 6speedmobile app and I can't find a DIY for the clear corners ,, only access is they the wheel well imma assume ,, thanks in advance ...
Old 04-18-2012 | 05:47 PM
Munch's Avatar
Munch has much to be proud ofMunch has much to be proud ofMunch has much to be proud ofMunch has much to be proud ofMunch has much to be proud ofMunch has much to be proud ofMunch has much to be proud ofMunch has much to be proud of
Did you buy your lenses yet?
Old 04-23-2012 | 04:02 PM
ferraristyle's Avatar
ferraristyle has a spectacular aura aboutferraristyle has a spectacular aura about
Simple job but time consuming (the top bolt is crazy hard to get too). Take off the wheel well liner, no need to take off the tires, just turn them inward on the side you are working on.
Two torque screws hold in the light. The bottom is easy to get out, the top is hard only because there is limited space. You need a wrench with a troque drive end to make this simple. A flex driver may work but I used the wrench.
Once you get the light off, I found it easiest to screw in the top screw to hand tight, then use the wrench. Just be patient. I think there is a write up over on rennlist or renntech.
Old 04-23-2012 | 05:49 PM
GTS Jay's Avatar
GTS Jay has a spectacular aura aboutGTS Jay has a spectacular aura about
I don't think you need to remove the liners completely - just enough to bend them back a bit to get to the lights...
Old 04-25-2012 | 07:49 PM
Correct. I just removed to the middle and pulled back.
alevine
11-04-2015 10:05 AM
riverflyer
09-01-2015 04:22 PM
gulf gt
08-27-2015 10:27 AM
Zero911
08-24-2015 06:51 PM
TrackOne
08-20-2015 12:56 PM
Quick Reply: DIY clear corner mod
