Have an 08 Cayenne Turbo? Need Front Rotors? Found a deal...
Old 12-02-2012 | 04:16 AM
loveivs's Avatar
loveivs is infamous around these parts
Originally Posted by Renaissance.Man
You are right. I believe the factory OE Brembo replacement is the 09.9870.10, where the "premium" Brembo replacement is 09.9870.11.
Sorry, I did not take any before and after pictures, since the "after" would have been used rotors - so not an apples to apples comparison. However, I did noticed when they arrived that the hat area received a thicker, dark-grey metallic paint of much better quality around this area (see original attachment). It is visibly more attractive and should provide better corrosion resistance. Compare this to the factory rotor, where you pretty much see a matte grey primer sort of finish that should some minor hint of rust after a couple of years. This one should hold up much better.
I have been on this Brembo rotor set for about 2,000 miles. Fits like a glove! Very happy with this purchase. Anyone else who jumped on it will be ecstatic too. Very glad I have a spare set in my garage.
Sorry to hear that. Unfortunately, I will not be qualified to answer this question since I have primarily aggressive miles on my CTT (read: so this isn't a GT2?!) so I swapped out the factory pads for Carbotech XP8 light race/autocross pads on it daily. Much better grip with the SS lines and Castrol SRF fluid swap.
I was told our ctt lines are SS. The hose itself is made of rubber/plastic. Inside is SS. If factory lines are not SS, I should have them changed when I replace the pads and fluid.
Did you change the pads and lines at the same time you replaced the "premium" rotors? because it is hard to believe simply change the rotors will make big change and gives much better stopping power =)
Old 12-02-2012 | 08:27 PM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
I took several pictures and analyzed the new replacement SS brake lines with the OEM brake lines - trust me, the OEM lines are just standard rubber lines.
Brembo, the caliper manufacturer, even sells an SS line upgrade in their UK catalog for the 957. Unfortunately, Brembo US does not sell them - which was confusing when I called them.
I think you misunderstood me. I credit my increased stopping power to the Carbotech XP8 race pads (better fade resistance), SS lines (better brake line pressure), Castrol SRF (highest wet boiling point brake fluid), 911 GT3 brake ducts (additional rotor cooling) together - not the "premium" rotor. I think the "premium" rotor will just have an easier time preventing rust.
Old 12-03-2012 | 02:02 AM
loveivs's Avatar
Goodridge lines have been ordered. Thanks for the correction my friend!!
Old 11-30-2015 | 01:59 PM
KarlC's Avatar
KarlC is infamous around these parts
Renaissance Man can you provide any suggest updates for the 2008 CTT , the ebay link is dead.
Here is 1 way I was thinking of going, ECS kit with Front Rotors, Pads, bolts and Sensors for $380 ......
https://www.ecstuning.com/Porsche-20....51/ES2602359/
Old 12-08-2015 | 01:17 AM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
ECS is a good deal!
I bought rotors using part# off the Brembo site Ken posted. $200 shipped for fronts and $160 shipped for rears on AMAZON!
Sensors are $20 shipped for a set of 4 on Ebay. I also found the EBC yellow pads on Ebays for the lowest price.
Old 12-08-2015 | 02:35 AM
KarlC's Avatar
Originally Posted by dgreen78
ECS is a good deal!
Would you mind posting links to all those items ?
Thx
Old 01-17-2023 | 03:17 PM
Jetson's Avatar
Jetson is infamous around these parts
Did you guys have good luck with these?
What sensors work, and which pads have been your favorite so far?
socialpro
Cayenne 958
05-18-2016 10:58 AM
PelicanParts.com
08-20-2015 04:00 PM
PelicanParts.com
Cayenne 958 Vendor Classifieds
08-20-2015 03:59 PM
PelicanParts.com
08-20-2015 03:57 PM
Yotam Refael
Cayenne
08-18-2015 04:03 PM
