Check Engine Light after mods?
Well I am now getting a check engline light after installing my 200 Cell Primary Cats, 2nd Cat Bypass and Fabspeed Exhaust system. I only have the Evoms Intake.
Before installing the full exhaust system I had no issues. After I installed it and drive maybe 5-10 miles it throws the CEL. I can reset the light and then it will randomly come back on again after 5-10 miles of driving.
The codes it throwing below are the following based on my Durametric. I know the cats are supposed to be CEL code free. It is a 2005 with 67k miles. Is it normal and possible that my o2 is failing?
P0421
Catalyst System Efficiency Below Threshold Bank 1 - Upper limit value exceeded, test conditions are not-completed, fault is currently active and causing a DTC light
P0431
Catalyst System Efficiency Below Threshold Bank 2 - Upper limit value exceeded, test conditions are not-completed, fault is currently active and causing a DTC light
P0299
Turbo/Super Charger Underboost - Value below lower limit value, test conditions are not-completed, fault is not currently active and is not causing a DTC light
P0421
P0431
P0299
Well I think I just figured out my underboost problem. My driver side diverter valve had a hose that came off. It was the smallest hose of the 3. Interested to see if that small hose could cause a CEL.
Sounds to me like you need oxygen sensor extenders since the 200 cell cats are flowing much more exhaust than the stock cats. Did you install any?
Also, like you said, the P0299 code is unrelated to primary DP swap.
If you need a link to a O2 extender that will work for your application, shoot me a PM.
Wouldn't this lead to the car running lean? Cause now by tricking the system your air fuel ratio would be incorrect right?
No, you have two pair of O2 sensors per side - 4 total. The ones that affect AFR ratio are before cats (do not touch those). The ones that read the efficiency of the cats are placed after the cats (downstream). The second pair of O2 sensors ONLY measure the efficiency of the cats - no AFR at all.
Mini George
07-29-2019 12:20 PM
Mini George
01-18-2016 09:16 PM
tropicatango
10-14-2015 11:32 PM
