Warning 957 Cardan Shaft and Horns Replaced
The cardan shaft failed in my 2010 GTS at 48.5K miles. Also, test your horns, there is a design defect that allows water to seep into the contacts that corrodes them. I've experienced this on two 2010 957's. My passenger seat airbag and seat sensors were also replaced, this seems to be anotber common failure, at least according to my SA. Thank goodness I was still under my OEM warranty, otherwise $3K.
are coolant pipes fixed in 957s? i think early 957s still have plastic.
957s have a totally different coolant distribution system. They use a single coolant pipe under the intake plenum, instead of the 4-pipe system that the 955 used. It is a plastic pipe, but I don't know of any cases of it failing.
958s also continue to use the same style of horn in a location which is likely to allow moisture to get to them.
Looked at SWMBO's new Lexus RX-350 yesterday. I can see the horns through the front grille.. they appear to be FIAMM clones (snail type horn.) What's interesting is they have a plastic cover over the horn opening. It doesn't quite seal to the horn, sort of clips on. The horns are mounted directly behind the upper grill, about centered on it vertically.
If I had to guess the covers are to prevent water intrusion when splashing through big puddles. The horn openings also face down (which likely helps.) Wonder if something like this might help the Cayenne horn problem? Perhaps we could borrow an idea from Lexus' Relentless Pursuit of Perfection (you think they would have found it by now..)
04-28-2022 12:38 AM
pwdrhound
08-23-2015 07:36 PM
Yotam Refael
Cayenne
08-18-2015 03:03 PM
