Anybody ever try 295/40/21 tire size on GTS wheels?
Old 03-04-2013 | 11:06 AM
kebbin's Avatar
kebbin is infamous around these parts
Has anybody ever tried running a 295/40/21 tire size? Any issues? The stock size 295/35/21 overall diameter is 29.1" and the 295/40/21 overall diameter is 30.3", just about a 4% difference. Trying to think if I should bother since its about time to replace the tires on the GTS wheels. Thinking it might provide just a little bit more cushion.
Thanks!
Old 03-04-2013 | 12:56 PM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
My new tire size 305/35/22 is 30.4". This is about the same as your proposed 30.3" setup. It will clear fine, however, you will have superficial rubbing on a small portion of the fender lining if you do not stretch it out.
Old 03-04-2013 | 09:06 PM
bansasn's Avatar
bansasn is a name known to allbansasn is a name known to allbansasn is a name known to allbansasn is a name known to allbansasn is a name known to allbansasn is a name known to all
What do you mean by "if you do not stretch it out"? I am planning to put 305 on my 2005 CTT. Does your rubber? Thanks!
Old 03-04-2013 | 09:07 PM
bansasn's Avatar
oops...I meant rub not rubber.
Old 03-04-2013 | 10:35 PM
Moderator
Yep. It will rub slightly on the fender lining right in front of the intercooler when turning near full lock. I started to stretch the fender lining in that area by placing a few layers of cardboard on top of the wheel and lowering my CTTS in its lowest stance to apply pressure on the trouble area overnight. It has gotten much better. I checked and rechecked and if it wasn't for the rubbing sound (read: annoying), I would leave it alone.
Old 07-21-2015 | 01:45 PM
zzzx's Avatar
zzzx is infamous around these parts
just want to share my experience.
I installed 295/40/21 yesterday(factory continentals are finished only after 9 month/25000km driving). like Renaissance.Man's experience, the tire is rubbing the wheel liner when turning. I went ahead and cut the bottom 1" of the plastic inter-cooler grill in front of the wheel and zip the liner against the hard plastic that is attached to the aluminum inter-cooler body. it gave me about 1/2" clearance now.
ModBargains
Audi Vendor Classifieds
09-01-2015 05:26 PM
ModBargains
08-20-2015 12:28 PM
08-19-2015 06:35 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
08-18-2015 03:42 PM
PelicanParts.com
997 Turbo Vendor Classifieds
08-18-2015 03:41 PM
Quick Reply: Anybody ever try 295/40/21 tire size on GTS wheels?
