IPD Plenum Install
IPD Plenum Install
Installation
After waffling back and forth on this upgrade, I finally decided to go for it. The plenum arrived and it's a very nicely finished and machined piece. The install is really quite simple.
1. Remove front engine cover.
2. Disconnect wiring harness from throttle body and boost pressure sensor.
3. Loosen hose clamps on outward side of intake hoses connected to Y plenum and slide off intake pipes.
4. Remove pins securing Y plenum to throttle body.
5. Slide plenum off throttle body.
6. Disconnect air hose at bottom of Y plenum and remove Y plenum assembly from vehicle.
7. Transfer intake hoses to IPD plenum and secure clamps on sides closest to the plenum. Screws on clamps should face rearward.
8. Remove boost pressure sensor from stock plenum and install in IPD plenum.
9. Remove metal retaining pins from IPD plenum.
10. Transfer hose bracket from factory plenum to IPD plenum.
11. Position IPD plenum for installation and reattach bottom air hose.
12. Slide intake hoses on air inlet pipes and lightly tighten hose clamps in position.
13. Slide IPD plenum on throttle body until its fully seated and reinstall two metal retaining screws to secure plenum to the throttle body.
14. Once in position, make any final adjustments to hose positions and fully tighten hose clamps.
15. Plug connectors back in for boost pressure sensor and throttle body.
16. Reinstall engine cover.
17. Done.
Here's a shot taken after installation, but before plugging the electrical connectors back in:
And here's a shot with everything back in place. The metal finish dresses up the engine compartment just a bit.
Driving Impressions
I did not dyno my vehicle before doing the install, nor do I have plans to dyno it in the future, so as much as I'd like to be able to report actual before and after dyno results I can't. But I can report actual driving impressions.
My first sense was that air flow to the engine was definitely enhanced - quicker responsiveness with throttle input and faster acceleration through the gears. I did this with no real expectations of achieving the claimed HP gains, but now that it's on, I will say it makes a perceptible difference in engine performance and I'm keeping it. A tune would pull all of this (2nd cat bypass pipes, APR diverter valves and IPD plenum) together, but the CTTS is now almost scary fast as is for a vehicle of its size, and I'm not even sure I need the tune now. If you have some spare cash laying around, I'm going to give this upgrade a double thumbs up!
17. Done.
Driving Impressions
PenguiN
09-15-2015 11:44 AM
