03 CTT Sitting lower on one corner??
Old 07-26-2013 | 06:43 AM
Diablo96's Avatar
Diablo96 is infamous around these parts
Gents,
I have recently noticed that when my CTT is parked (no had a chance to view it while on the move), it sits lower on the RHS. Looking at it closely, it looks like the front RHS corners is sitting lower. The suspension goes up and down fine on all four corners.
Could this be an adjustment that needs to be done via the diagnostic, as I had to do on my Audi?
The car went for its annual inspection and they jacked it up without locking out the air suspension and wondering if this did something to it.
Thanks in advance.
Old 07-26-2013 | 07:17 AM
Dennis C's Avatar
Sounds like a leaking air shock. Does it level itself when you start it, or does it stay the same way?
Old 07-26-2013 | 07:18 AM
XR4Tim's Avatar
XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !
Yes, you probably just need to calibrate the sensors with a Durametric or PIWIS scan tool.
Old 07-27-2013 | 05:59 AM
hadydaddy's Avatar
hadydaddy is infamous around these parts
how to lock out the air suspension before jacking the vehicle
my car was lower at the FRHS completely, but the second i started the car it leveled itself..this doesn't happen too often
Old 07-27-2013 | 07:44 AM
Diablo96's Avatar
Thanks for the opinions.
Does the calibration take long to do? I recall that my A8 took 4-5 hours of playing around to get it right. I hoping that the Porsche system is a little more user friendly...
Old 07-29-2013 | 07:30 AM
XR4Tim's Avatar
Shouldn't take near that long. Read through this tutorial, it's for lowering, but the same technique can be used to simply level the suspension:
https://www.6speedonline.com/forums/...etric-diy.html
Old 07-30-2013 | 03:46 AM
Diablo96's Avatar
Thumbs up
I will have a go. Much appreciated.
Old 08-04-2013 | 04:21 PM
sinktheboat's Avatar
sinktheboat is infamous around these parts
check the link rods from top of suspension arm to chassis isn't damaged or popped off.
it tells the sensor what height the car is! one one each wheel.
http://www.adjustableairride.com/PDF/Cayenne.pdf
DLF
Cayenne Turbo
10-24-2015 12:27 PM
proTUNING Freaks
09-15-2015 08:28 AM
Quick Reply: 03 CTT Sitting lower on one corner??
