Oil leak near oil pressure sending sensor
Do or did any of you with a 08-10 Cayenne S have oil leaking in the area of the oil pressure sending sensor located above the oil filter? If so, have you had success with correcting the oil leak with replacement o-rings or is it the actual sending sensor that was the culprit?
Or.....is it something else I am over looking.
Thanks for that help!
bond
01-31-2006 11:07 AM
