Jacking up/Jack Stands/ Adapters
So I want to tackle the eventual brake job on my 2005 Cayenne Turbo. They're not ready to do any time soon, but I do have other maintenance items like the diverter valves to replace.,
My question is, what jack stands do you all recommend and what Jack/Jack stand pads do you suggest I use? I'd like to get all four corners off the ground safely.
Pads/stands/jack recommendations please!
I don't want to use a hunk of wood, or have to chop down a hockey puck. I'd rather just buy the tool..
Thank you all!
Also, I REALLY want to do my own oil changes..so this would help anyways.
Thank you all!
Thank you all!
Thank you all!
They look like jack adapters (thou, that is a Kluger/whatever they are called anywhere else).
Here are some pre-made hockey puck type adapters;
https://www.ebay.com.au/itm/Porsche-Macan-Jack-Pad-Rubber-Porsche-Cayenne-Jacking-Pad-Rubber-jacking-pad-/273104057168
FWIW, I jack ours up like Pelican says and have had no issues.
If you've got air suspension, make sure you lock it in position.
