Best ECU upgrade for cayenne turbo?? dms? giac?
Old 01-23-2007 | 01:08 AM
ehaser1's Avatar
ehaser1 is infamous around these parts
Can anyone tell me which ecu gives the best low end power for the city? I'm looking to get rid of the lag that is present. I've read on renntech that dms with air filters and bypass pipes will net 540hp whereas giac gives around 510?
Anyone have real world experience on this? I need to do somthing soon.
Old 01-23-2007 | 08:52 AM
George@Revo's Avatar
George@Revo is infamous around these parts
Our program for the Cayenne TT will [u]dramatically[/] reduce throttle hesitation. In the non-turbo models, it's even adjustable. Timing can be adjusted to give you a little more low end acceleration as well. Estimated numbers are 515HP and 530 lb/ft of torque. Let me know where you are located and I can direct you to your nearest authorized Revo Technik dealer.
Old 01-23-2007 | 11:37 PM
ehaser1's Avatar
I live in chicago..
I'm looking for the turbo ecu upgrade.
Old 01-23-2007 | 11:44 PM
turbomaxima's Avatar
turbomaxima is infamous around these parts
what about upsolute?
Old 01-23-2007 | 11:52 PM
Neil@Orton's Avatar
Neil@Orton is infamous around these parts
There are many to choose from.Do some research and go with the tuner that you are comfortable with.
Neil
Old 01-24-2007 | 12:09 AM
Rider1's Avatar
Rider1 is infamous around these parts
I've owner two CTT's...an '05 and an '06. Did the GIAC ecu upgrade on both and the BMC air filters and Fabspeed secondary cat bypass pipes on the '05.
You'll never get rid of the lag totally because it's a combination of poor communication between the engine and transmission (however they do that) and turbo lag. I was so frustrated that I went to drive the ML63 and couldn't believe it! No lag and a very responsive transmission. Got rid of the CTT on the spot...at a large loss to boot. The CTT interior IMO is a little nicer/sportier than the ML63 but let me tell ya when u step on the gas it goes RIGHT NOW! Nothing makes me happier!
Just my .02
Dave
Old 01-24-2007 | 06:28 AM
YSS's Avatar
YSS
YSS is infamous around these parts
Spot on
ML63 is incredibly powerful and responsive.
i decided to buy an 08 Cayenne anyway
Old 01-24-2007 | 08:23 AM
Rider1's Avatar
Originally Posted by YSS
Spot on
Enjoy it! And please give a report after you've taken delivery of the '08 Cayenne. Engine should be more responsive with the direct injection. I'll be lookin' at the '09/'10 CTT or whenever the next "version" comes out.
Dave
Old 01-24-2007 | 10:38 AM
JAY@BRANDYWINE's Avatar
JAY@BRANDYWINE is infamous around these parts
GIAC is the only way to go, i have flashed alot of CTT and have had great success, with this program you do still have turbo lag, but its a turbo charged car, you can never completely get rid of turbo lag with out major mods, GIAC all the way
Old 01-24-2007 | 10:54 AM
I hear what you are saying, I am just curious as to what the 'reasons' are behind not using upsolute or dms (or any of the others)? Upsolute makes more power than GIAC, correct?
Old 01-24-2007 | 11:02 AM
this is correct, they do make more power, but they do it by upping the boost, which can burn out your turbos prematurely, this can get costly.
Old 01-24-2007 | 01:15 PM
Rider1's Avatar
As a side note regarding my using the GIAC updates I found that when I used 100 LL the vehicle ran much better i.e. smoother and felt stronger too. Still had the trans./turbo lag but slightly better.
Dave
P.S. Had the "regular" GIAC upgrade done, not the hi octane version.
Old 01-24-2007 | 01:23 PM
I live in chicago..
We have a dealer in Bensenville. Midwest Eurosport. 630-595-5577. Ask to speak to Nick.
Old 01-25-2007 | 12:23 AM
ehaser1's Avatar
I don't know anyone in chicago that sells the higher octane fuel? All we have is the 93 octane..
So how do you run the 100LL?? Where do you get the fuel?
Old 01-25-2007 | 08:35 AM
Rider1's Avatar
I'm in Las Vegas, NV and a gas station called "Rebel" sells the 100LL here for about $5 per gallon. When I had the CTT's (I now own and love the ML63) I would mix the 100LL on a 1 to 3 ratio. i.e.: 15 gallons total with 5 of that 100LL.
POI: The ML63 showed no noticeable difference when I tried the 100LL.
Dave
Quick Reply: Best ECU upgrade for cayenne turbo?? dms? giac?
