Tires for 22" Wheels - 295/30/22 or 285/35/22
I had both 295 and 285 on my 22X9;.5 D'vinci Carismas black with spacers, unfortunatley they vibrated to having wrong offset of 22" wheels, Never noticed anything with new tires but I would go for the 285 because it has more rubber between the lips and the road; which gives a smoother ride.
I would suggest the toyo's proxes if not mistaken.
Does anyone know if the speedo can be easily calibrated for the larger tire diameter. I really want to go with the 285/35 for a little more sidewall. Let's face it these things are still SUV's. According to http://1010tires.com/TireSizeCalculator.asp the 285 is 3.99% larger and at 60 the speedo will only read 57.6. The 295/30 is only .04% larger and at 60 will read 59.6.
Huh? Actually if you run the 285/35x22 at 58 mph your speed will only read 55.69 mph. If your point is at 60 or 70 mph I shouldn't worry about 2 or 3 mph. I guess I get it. My only concern is if I have some gung ho trooper following me I wanna know how fast I'm going. They are a little tough on the freeways here in Ohio. Of course with the Turbo S I could try to out run them. Hard to out run radios though.
COBB Tuning
11-09-2015 08:02 PM
oufan2929
11-08-2015 08:26 PM
Sterlingc1975
08-22-2015 02:30 PM
