Just put NGK spark plugs iridium IX in my CTT and the car woke up.
Stock Beru iridium plugs are garbage I put these in my stage 2 Cayenne Turbo and the car woke the F up. Feels awesome. Anyone else try something different then stock in there CTT? I also regapped them to .025. I was definitly blowing spark out before this.
-Suman
-Suman
Same heat range(6) NGK BKR6EIX 6418 regapped to .025 like my 996 turbo. World of a difference. No more spark blow out. Car feels smoother stronger, idles better. BERUS ARE CRAP! they failed in 1000 miles in my 996tt. thanks
regapping is key the ond plugs were .032 and thats to much for the flo of air. thanks
-Suman
-Suman
I got hicups while accelerating with full boost. I also have a stage 2 CTT with intake exhaust chip etc. so it might not happen to stock cars. It feels like a split second loss of power. No smoothness through the band. PS Beru is garbage
-Suman
-Suman
I have a 04 cayenne TT with an evom tune. I have been now getting issues with studdering around 3-4500 rpm range. I did not notice this initially after the tune because I was dealing with ignition issues that cleared up by replacing coils and sparks plugs (OEM beru) fuel filter, evap hoses. Now those issues are fixed but I still feel like it is an ignition issues and noticed that you recommended ngk spark plugs over OEM beru for tunned cars. Could this be my problem and should I try a different spark plug, and if so what brand and gap should I do? Thanks.
I just put in a set of Denso IK22 Iridiums a couple of weeks ago (gapped to 0.8mm). Mainly because they were iridium (stock is platinum), seemed to be the plug of choice for many 997TT tuners, and 1 step colder.
Can't say the effect of just the spark plugs since I did other mods at the same time. I was happy to send back the more expensive OEM plugs - no regrets.
The model number is IKH22 (5345) for the MY08 CTT application. .
Please make sure you regap them carefully at 0.8mm. If you apply to much force at an angle, you will snap off the iridium tip.
I went with the NGK heat range 6 iridium spark plugs and it definetly made the surging problem almost completely go away. A few episodes at WOT but I wonder if I should go with a colder heat range of NGK such as the 7. Any thoughts as if this would make things even better.
PorscheEnthusiast
11-13-2015 02:23 PM
08-20-2015 12:17 PM
