2nd Gear Starts?
Old 03-07-2007 | 08:13 PM
jtcturbo's Avatar
jtcturbo is infamous around these parts
2nd Gear Starts?
can someone tell me why the CTT always start on 2nd gear from a stop? also, is there a switch to make the car start in 1st gear all the time? TIA.
Old 03-07-2007 | 08:16 PM
BobbySpeed's Avatar
BobbySpeed is infamous around these partsBobbySpeed is infamous around these parts
Turn off the PSM.
Old 03-07-2007 | 10:33 PM
emissary's Avatar
emissary is infamous around these parts
I always just manually downshift prior to taking off...it makes me feel like I'm doing something...
Old 03-08-2007 | 02:54 AM
techm8n's Avatar
techm8n is infamous around these parts
Originally Posted by BobbySpeed
Turn off the PSM.
It still starts on 2nd even when I turn off PSM. I have a 2004 CS.
Old 03-08-2007 | 08:57 AM
Dr_jitsu's Avatar
I think, for ****s and giggles that I am going to run my CTT in the 1/4 miles at the Supra Nats next week. Any advice beyond just point and floor her?
I suppose starting in second is ok...should I break boost?
I am entering the GT2 in the 60-130 and tracking her, but I won't subject her to the abuse (wheel spin/hop, clutch fry) of the 1/4.
Old 03-08-2007 | 10:43 AM
emissary's Avatar
I would figure you would want to start in 1st for a quarter mile run, although I'm not sure what it will do with PSM off. Certainly with PSM on, just drop it to first and floor it...it should redline from 1st to 2nd (with obviously no wheelhop). Without PSM...well, I haven't done that yet...I'm not that brave...
Old 03-08-2007 | 10:46 AM
Dr_jitsu's Avatar
I have tested her acceleration w/ PSM on and I get no shut down since there is not enough power to spin the tires. If I break boost I might lose traction so I suppose I will have to experiment.
Old 03-08-2007 | 03:02 PM
emissary's Avatar
Somewhat off-topic question here, but I noticed in your sig you have a 2004.5 CTT listed...how does one distinguish between a 2004 and 2004.5 CTT?
Old 03-08-2007 | 05:19 PM
BD 997's Avatar
BD 997 is infamous around these parts
I dont think you can...
Old 03-08-2007 | 05:49 PM
BobbySpeed's Avatar
With PSM off my 2006 starts in 1st, and doesn't go to 6th even on the hwy (unless I upshift), I am unsure if this was or wasn't a feature in 2004.
Old 03-08-2007 | 05:59 PM
jtcturbo's Avatar
Turn off the PSM.
u are correct, tried it yesterday w/o PSM and car starts in 1st gear from stop. but w/ PSM on, CTT will always start in 2nd gear.
Old 03-08-2007 | 06:02 PM
kooser's Avatar
kooser is infamous around these parts
As already mentioned above - just manually downshift to 1st from a stop, no need to shut PSM off. But also as noted above this way works too, I just like keeping PSM on, but PMS off with shorty!
Old 03-08-2007 | 06:07 PM
jtcturbo's Avatar
i have been doing that but just a PITA to have to manually shift it into 1st everytime i am at a stop.
Old 03-08-2007 | 08:50 PM
BobbySpeed's Avatar
I take it you are usually an automatic transmission guy, whereas I always buy a manual.
Old 03-08-2007 | 09:27 PM
Dr_jitsu's Avatar
The 2004.5 has the alcantara (suede) headliner.
My research found that CTT's built after late 2003 (say November on) had less problems than those built earlier in the year.
Quick Reply: 2nd Gear Starts?
