factory option rear view camera question
I'm trying to get some idea of where to install a rear view camera in my cayenne. I couldn't find any actual images of the factory option on google or search on this forum. Can anyone that have the factory option rear view camera take a picture of where the camera is mounted? I just want to see how it's mounted and if I can use any aftermarket camera to duplicate the same mounting area.
tia
tia
Originally Posted by G_A
camera in license plate area works good. Will you connect camera to PCM or another screen?
Alex.
Alex.
Original motorized camera installed in center of plastic trim lower rear window. It is possible to order all original parts, do not ask me about price, you can find all numbers in part catalog on porsche tech site. camera need power and one activate signal to open and produce conventional NTSC mirror image on output and can be connected to any suitable screen. Regarding PCM - I did it with 2006 PCM2.1 and I think it is not possible to do it with 2.0. anycase you need activate function with system tester.
Regards.
Regards.
Regards.
Regards.
