Just put 22s on my CayenneS !
Ok guys I just got a pre-owned Cayenne S and put on a set of OZ 22s with 285/35/22 tires and the back two wheels look perfect but the front two not so much. I mean the front wheels stick out maybe a half inch and it just doesn't look right. They are already bolted on the car what the heck should I do?
Would tirerack take them back even though they were installed already ? Do I need to run a staggered set up ? I am lost and kinda bummed.
I have the same wheels with 285/35/22 tires as well, and I know what you mean about the front sticking out slightly more than the rears. If you look at the car from the front, you can clearly see the front wheels coming out just past the fender, about 1/2" or so.
Is your car lowered? If not, drop it and it will look 1000 times better. When the car sits up high, the gap along with the wheels slighly coming out looks horrible. Surprisingly, when you sit the car lower, it actually improves the look.
Originally Posted by porschespeeddem
One option would be to do the wheel arch extensions. Would give the illusion that the vehicle is wider.
