K&N Replacement Air Filter
Old 06-03-2007, 08:36 AM
BD 997's Avatar
BD 997 is infamous around these parts
Anyone replace their stock air filters with K&N or any aftermarket filters? If so... any difference? Thanks...
Old 06-03-2007, 12:49 PM
RDKJ's Avatar
RDKJ is infamous around these parts
I ordered a pair of BMC air filters from Fabspeed yesterday. I am quite sure that any improvement will be nominal, but it was a cheap mod.
Old 06-03-2007, 01:06 PM
MeanMachine's Avatar
Ive got BMC's no difference mostly sound, in which it is throatier and deep however when coupled with a Exhuast system and Ecu's if felt the difference.
I am just adding my experince, whilst a 08 Turbo obviously gains much much more. BD 997 why dont you install Bypass pipes, diverter valves, RSS Plenum and then custom tune your ecu for everything to work in optimum levels including the drop in K&N Filter.
Old 06-03-2007, 01:24 PM
BD 997's Avatar
I may do a few of those... I dont want the car to sound too loud... im worried the bypass will make it too loud.
Old 06-03-2007, 01:47 PM
Pierre996TT's Avatar
Pierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura about
my wifes cayenne S has bypass pipes...and she did accepted (she does NOT like sporty sound) in fact the increase in sound is minimal and for a Turbo is even less with more power gains
Old 06-03-2007, 03:19 PM
Griza's Avatar
Griza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud of
The BPP's don't make it too loud just a little throatier when accelerating...
Old 06-03-2007, 09:35 PM
BD 997's Avatar
ok...im convinced. Ill call fab on monday....hope they got it in stock. BTW does a exhaust pro have to install or can anyone do the simple bolt on?
Old 06-03-2007, 09:49 PM
RDKJ's Avatar
My understanding is that you have to cut the existing exhaust. This is what the service manager at my local P dealer told me. I ordered Friday...
Old 06-03-2007, 09:58 PM
BD 997's Avatar
how much did you pay? Are you keeping your 21's? I think I might sell mine for winter tires after I get my 22 or 23 Rinspeeds.. didnt decide which to get yet
Old 06-03-2007, 10:03 PM
RDKJ's Avatar
I have not received the bypass pipes yet. My P dealer quoted $300 for the install. They should arrive Tuesday.
I will be disposing of my 21"s shortly - I am not a fan of the wheel. I received the Gemballas, but one wheel was damaged (bent). I am just waiting to for Hienz to send the replacement next week.
So far, the only thing I have done is window tint and V1 hardwire. I will wait and post pics after the Gemballa's are one. So far, so good with the 2008 - the throttle response and the ride are much improved compared to the 2004 I owned previously.
Old 06-03-2007, 10:33 PM
BD 997's Avatar
have you tried switching off traction with sport on? night and day difference... I love it!
Old 06-03-2007, 11:13 PM
BD 997's Avatar
dont forget lowering links... its a must especially since your changing your wheels... the lower center of gravity will make the wheels look nicer and the car more aggressive. Also I didnt think they had the NEW plenum out yet... they have the 06< available but they were testing the 08's... make sure you ask for the 08 because I guess the 06's were a bit different....
Old 06-04-2007, 06:46 AM
RDKJ's Avatar
I will add the lowering links and plenum eventually. Hopefully the 22's fill the wheel well plenty, especially with the 285/35/22 Yokohomas. If the plenum is not yet available, then I will flash the ECU next.
I have turned the traction control off in sport mode, quite a difference from my 2004 CTT.
Old 06-04-2007, 08:37 AM
Griza's Avatar
Don't go to a dealer for this. Go to a Porsche independant and it is a simple bolt on. You take off the secondary cats and put the BPP's in their place. My local independant charged me $100.
Old 06-04-2007, 08:53 AM
BD 997's Avatar
I would never go to the stealer for that type of work.... I'll probably take it to TCM a member here... they did my links.
Quick Reply: K&N Replacement Air Filter
