Any suggestion on preventing the swiral marks ?
Old 04-20-2004 | 03:16 AM
elise386's Avatar
elise386 is infamous around these parts
Being this is the first time I own a Black (non-metallic) car, I never realize that everytime I wash and dry the pepper, no matter how careful I was, swiral marks always resulted. Anyone has any suggestion on how to remove and prevent them from happening ? I have always hose off the car with high pressure hose and I have been extremely gentle when it comes to wash and dry!
Old 04-20-2004 | 02:39 PM
james's Avatar
Carolina Speed
james is infamous around these parts
porter cable random orbital buffer with either wax or polish in between waxes. Also, if you use a clay bar it is amazing the shine that can be achieved separate and apart from the buffer.
Old 04-20-2004 | 03:43 PM
JM996's Avatar
JM996 is infamous around these parts
Don't get black is the best suggestion I can think of, but it sounds like it's too late for that
Old 04-20-2004 | 04:42 PM
jamy85's Avatar
Boobie Stars
jamy85 is infamous around these parts
1st advice never have it washed by doctor detail etc, they dont give a rats *** about ur car and all the swirl marks in my car is the result of them. For drying i use this thing called micro fiber magic towel.. great results from it... or have ur car detailed my a prof detailer!!
Old 04-20-2004 | 06:12 PM
ffr996's Avatar
Senior Member
ffr996 is infamous around these parts
Jamy 85- Could you recommend a prof. detailer in Boston
Old 04-20-2004 | 06:13 PM
TCM's Avatar
TCM
TCM is infamous around these parts
Well, swirls are going to occur no matter what you do. Your main line of defense is minimizing them by using the correct two bucket washing method and only moving the mitt or pads in back and forth motions. In order to effectively remove heavy swirls, you need to have the car buffed by a professional. Check out www.autopia.org for more information.
Old 04-20-2004 | 10:15 PM
jamy85's Avatar
Boobie Stars
Talk 2 TCM he is on the board.... He is professional detailer; a lot of my friends recommended him to me. His shop is like 20min from Boston.
Goodluck....
PS ffr996....check ur inbox i sent you a private msg about the gemballa wheels a while back!!
Old 04-20-2004 | 10:45 PM
DEETZ's Avatar
GO 6SPEED!
DEETZ is infamous around these parts
Dr.Detail = swirls your car!!
I can only trust TCM he is the best
Old 04-21-2004 | 01:21 AM
Kevin M's Avatar
Modaholic
Kevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond reputeKevin M has a reputation beyond repute
Also invest in new towels and mits. Be sure to stick them in the wash machine without fabric softener after every use. Swirls come from dust and dirt on a towel they cause the scratches. Also get a California Car duster, wipe it down every time you take it out, or every other time. This will allow you to wash it every two weeks, the more its washed the more chances of swirls. Also get microfiber towels and Meguires Mist Spray detail. Use that in between washes to remove finger prints and dirt. I just clayed and used a orbitlal with Zymol HD Cleanse and Zymol Desting Glaze on my 996.. ... The results..
Old 04-21-2004 | 04:58 AM
Greyghost's Avatar
Greyghost is infamous around these parts
Swirls are scratches. Eliminate scratching surfaces and you minimize swirling. Clean washing mits rinsed several times during wash, clean drying towels washed regularly, cotton or microfiber only, and a quality polish and wax. I am a big fan or P21s however I recently switched to RejeX and am extremely pleased with the results.
Old 04-21-2004 | 03:42 PM
stilcrazee's Avatar
stilcrazee is infamous around these parts
3M makes a swirl remover for dark cars..most Pep Boys or Auto zone's handle it.
Lamb's wool mitt for washing. A claybar will get rid of the crap that causes small scratches. I use claybar with carwash soap as lube, not a detailer spray, you don't need to waste the detailer.
Microfiber towels are a must to dry. Terry cloth to wipe off polish or wax.
When you wax the sides, go top to bottom, not front to back, if there are the typical small surface scratches, it tricks the eye if they are up and down.
Try Zaino products for your car. They make a product Z5 for dark cars that also helps fill small swirls and scratches. Use this after you claybar car, then 3M swirl remover then the Z5, followed by Z6 from Zaino.
Old 04-22-2004 | 06:52 PM
greg schroeder's Avatar
greg schroeder is infamous around these parts
try this
Best product I've ever used
Old 04-22-2004 | 07:54 PM
HotRodGuy's Avatar
that new Tech Wax is hot
but a few tips, when you wax, don't go in a circular motion. Go w/ the wind.
Also get some good drying towels, www.properautocar.com a board sponsor has some AWESOME big blue microfiber towels. I own a few, one single towel will dry 2 cars
Paintballzen
10-10-2020 12:22 PM
Evan5469
10-29-2015 06:39 PM
Wheeler
09-22-2015 08:02 PM
BLKMGK
09-19-2015 03:51 PM
Quick Reply: Any suggestion on preventing the swiral marks ?
