Air in the back??
Air in the back??
Hey , I have a question. Does anyone know the trick to getting air in the rear? I have an 05 CS...and with the AC blowing low or mid strenght, theres no air coming from the center rear vents or the rear sides by the door. With it blowing at full strenght, theres VERY LITTLE air coming out to the sides by the door, probably not even enough to put out a match, and a whisper of air coming from the center rear if that.
The leave the blower setting on auto....but i tried putting it on the middle vents and still no air.
Any advice? Is this a problem that has to be fixed via dealer?
Not much of a fix, and you're not the first. Only thing I can suggest is to close the front vents a little bit, to force more air into the rear area. Should be able to close them half way or so and still get a good amount in the front with more in the rear.
Originally Posted by GoldenPEPPA
yes it is one of my few complaints with the car... I've found that when the fronts are closed @ 60% it works out pretty well.
(just givin' you a hard time still . . .)
04-28-2022 12:38 AM
tropicatango
10-14-2015 11:32 PM
