Newbie questions on a 2008 Cayenne S
I'm looking at a new 08 Cayenne S and had a couple of quick questions before I pull the trigger:
1 - The stock NAV system seems outdated.. so I was going to skip the NAV and get the base stereo package - I was planning on putting my own NAV system in.. My question is: Is the stereo space a double-DIN size?
2 - Are there any packages which I should DEFINITELY get? I was just going to go with the preferred package..
Planning on putting aftermarket wheels on as well.
Thanks in advance!
-Brett
Thanks in advance!
-Brett
don't forget PASM, especially if you're going with big wheels. Not only does it improve the ride with 20-22's but it also allows you to lower the car inexpensively with lowering links, like $250. Also memory seats if more than one driver, stock nav is not good. Depending on color maybe a black-pkg? Maybe sport exhaust? Leather interior if you're into that? Wood? Pref pkg is a nice combo of options.
Is leather not standard?
dont need memory seats - had them in my past few cars and never used em.. I really prefer the regular exhaust over the sport exhaust on the 08's..
anything else?
the bose is not a must have.
the nav is kool but if u can get a aftermarket wit touch screen, then i suggest that.
regular exhaust sounds great but the sports exhaust sounds AWESOME.
i dont even use the memory seats.
what color combo u gettin?
Leather seats are standard.
With the full leather package you'll get also leather on the dashboard, center console, armrest, door panels and steering-wheel airbag module. I didn't feel the need for it in the Cayenne (family truck) while I got it in my Boxster and I'll definitely get it again when I'll swap the Boxster for a 997 (hopefully soon enough...).
Thanks! I wasn't aware that PASM would allow me to lower the car for less.. as I will be putting on bigger wheels and wanted to lower it to narrow down the wheel gap..
anything else?
anything else?
Lowering links adjust the base height. It makes ALL the PASM settings X" lower than the base setting. So it'll give you lets say 1" lower at normal height for normal driving and a total of 3" total drop when parked. OR you can absolutely slam it on the tires if the ride quality isn't important.
Anything else? Mmmm... Pref Pkg, PASM, seat heaters if you're in a cool clim...
Have fun!
Brett,
I think the park assist is very useful when parking in a tight spot. Good luck with your purchase.
-Brett
-Brett
PM me for pics.
There is one practical disadvantage with PASM, that is when you need to change wheels. Say if you get a flat tire, and need to change it on the side of the road. I believe you need to do something to disable the PASM. Also, you may need to explain to a tire shop that your car has PASM when you ask them to replace the tires, and they may not know how to work with it.
Since I don't have PASM, I can't really offer more details...
thanks for all of the replies.. the only ones with PASM are too expensive for my current budget (they're all over 70k with PASM).. looks like i'll be getting a black/black S with preferred package and no nav (will be doin an aftermarket nav)..
nice. post pics when u get her!
Pasm
It is recommended to switch off PASM before lift car, but will not damage anything if will forget. Only will hear sound of air and wheels will mave a little for few seconds.
I hope you did try car with PASM. Be sure to check 2008 PASM because big difference from 2006 - more comfortable.
Regards
2lflat4
11-18-2019 05:05 PM
AJUSA.com
997 Vendor Classifieds
10-08-2015 05:50 PM
STAGGERED M3
09-11-2015 12:00 AM
PelicanParts.com
08-20-2015 02:57 PM
