ModBargains.com | Forgestar Wheels l Rotary Forged l Lightweight l Great Vaule !!!!!
The Forgestar lineup utilizes a combination of the best methods of forging and casting methods both in the same wheel. This is called rotary forging, and is used by companies such as BBS and Enkei. These wheels are custom made to order and can be made to fit your Porsche with a large range of available sizes, offsets and finishes.
Rotary Forging is a production procedure that turns the wheel (or rim section) over a special mandrel and three hydraulic rollers using tremendous pressure. The pressure and turning then force the rim area to form against the mandrel, creating the shape and width of the rim. During flow forming, the rim actually "flows" down to create the full rim width. During flow forming, pressure applied to the cast rim actually changes its mechanical properties, so its strength and impact values become similar to those of a forged rim. That translates to up to 15% less weight when compared to a standard cast wheel.
Forgestar Performance Wheels proprietary Rotary Forged Flow Forming technology allows the customers to choose between a range of offsets for every wheel width that is offered. The end consumer is able to choose a wheel that will perfectly fit their own individual vehicle. All Forgestar Performance Wheels are compatible with tire pressure sensor monitors and allow clearance for most high performance brake caliper upgrades. Take a look at this video to see how Forgestar wheels are made and finished!
CERTIFIED BY: SAE JWL VIA
Questions? Need Help? Give me a call here at 714-582-3330 x 8006 or ask for Alan !!
Tracking System
Industry First: As most of you already know, Forgestar wheels are custom made to order and do take 6-8 weeks upon the date of the order for completion. Forgestar has developed a tracking system that will help with the question of where are my wheels?! Each order will have a login/password set for customers to check up on the status of their order :thumbsup:
Interested in other Porsche wheels? Questions? Need Help? Give me a call here at 714-582-3330 x 8006 or ask for Alan !!
Can you PM me the price for all three kinds in 20x10.5 in standard finish? What's the most aggressive offset I can use on the 958 Cayenne without lowering? There's probably no rubbing issue as the car sits so high but I want it to be perfectly flush with the fender. Thanks a lot!
looking for pricing on F14 in bronze burst for 955 turbo S
interested in f14 in bronze burst for a 955 Turbo S 2006 and looking for pricing on the 20 inch and 22 inch sizes with various tire packages. I believe the best sizing is 20 x 10 and 22 x 10 but if you have different thoughts, please let me know.
PenguiN
11-12-2015 05:24 PM
ModBargains
Audi Vendor Classifieds
09-01-2015 05:26 PM
ModBargains
08-20-2015 12:28 PM
WheelB
Lamborghini
08-20-2015 12:25 PM
albert@velosdesignwerks
Other British Cars
08-20-2015 07:30 AM
