Headlights low beam H7 HID conversion
#31
Remove the headlight you will see the grounding connection.
You can run the positive side wiring inside the driver side fender.
To connect the passenger side ballast and oem connection, remove the center trim panel covering the radiator and run it along the radiator.
Nice clean install and the relay harness completely hidden.
(I also used a relay harness for my HID conversion for the fog lights)
https://www.6speedonline.com/forums/...onversion.html
#32
Would this work?
http://www.ebay.com/itm/D1S-D1C-D1R-...item27c13bfc98
It says it fits the 2011 cayenne... looks too good to be true?
#33
Waking up an old thread...
Wondering if this will work for stock projector headlights?
http://www.oemxenonshop.com/Porshce-...elacement.html
Has anyone found a cure?
nlakind
11-06-2015 10:15 AM
LiquidElephant
08-27-2015 06:17 PM
