Rattling in the Car
Rattling in the Car
Does Porsche fix any issues with squeaks or rattling?
As a previous BMW owner, anything under 50k miles that had to do with squeaks, rattles, trim, etch they would cover and fix under warranty. I brought my car in 4 times for them to adjust/fix the sunroof because it was making too much wind noise.
Is Porsche the same? I assume it should be even better.
I have rattling from my passenger seat but have not had them look at it yet. In my experience it will most likely end up with the famous line
"we were not able to replicate your problem, sorry sir". So I would not hold your breath. Worth a try at your next visit to the service dept, but I wouldnot go out of my way to get it done.
Both my p-cars have sqeeks and rattles. I just figure that's the way they are! My caymans brakes have sqeeled loud since day one rolling to a slow stop. I brought it to the attention of the dealer and yes I also got the "it's normal"
Of they have not replaced the suspect components (pads, rotors and hardware) then they don't have a leg to stand on.
I suggest to keep brow beating them and put it on the list for anytime you want to take the car in for warranty work or service. They will get the impression that you won't drop it and will have to try something.
You always have the avenue of requesting the regional rep to be involved and that usually helps motivate things. It at least takes out the desire of e dealer to get their bonus points for low warranty claims.
I have some wind noise in the bottom left corner of the driver window, and they can't seem to replicate it, nor fix it.
I had a spare "clean" diaper in the car so I tried stuffing it in the corner and the wind noise went away.
Also when I turn the air to recirculate, it goes down in sound a little as well, BUT I CANT STAND IT and with insulated glass when the car is SOOOO QUIET with my burmester, I want the interior to be as quiet as it can get.....
I just crank the music up and all goes away, but still would like the issue fixed.
They had a similar issue with previous cars, something with the side mirrors causing wind resistance and them reflecting off the window corner, but they say they haven't heard anything with the new Cayenne.....
sure..... Well you at least heard something from me, and that's enough, so go find and fix the problem.
Still not resolved.bah, but oh well. Not mind consuming, just wish it was fixed.
All other issues, rattles, or others, that have been replicated have been fixed.
I would actually do the opposite. You want to ensure that the problem is documented in their system so that if it becomes a bigger issue or is chronic, they cannot say "This is the first we're hearing of the issue."
PorscheEnthusiast
11-13-2015 02:23 PM
r_matt_6
10-08-2015 06:07 PM
