sudden check engine light
Today I started car and the auto start/auto stop error poped out. A few seconds after that a sudden check engine light poped out. I hope it is nothing serious
Any of you guys had the same issue or can give a hint !?
I have never had such an error message,just sometimes a crossed yellow(instead of green)indicator "A"
It is what you get when you deactivate the auto start/stop function
It sometimes turns itself off if you are also draining the battery too much in other ways:"Ac,seat ventilation,music..."
Good luck and keep us updated
If it stays solid you can drive it in to Porsche, if it a blinking check engine light they recommend towing it in. (call your dealer to be sure) I towed mine in. My engine light was blinking nd the car bucked/vibrated heavy as I accelerated. I had a faulty fuel injector just out of warranty by 6 months on the older generation 08. Towing is supposed to be free if you are under warranty.
I took my car for diagnosis, the scanner threw a p0700 code which is a transmission error ( Control for additional hydraulic pump for transmisioon oil feedback signal too low)
I'll be taking it to the dealer tomorrow
I hope its a sensor only nothing serious
Ayways, drove it straight to the dealer. They said it was an electronic control unit to be replaced. Got the car back in 2 days and they performed the headlight recall during same visit.
Nothing to be worried about
Mini George
07-29-2019 12:20 PM
Mini George
01-18-2016 09:16 PM
tropicatango
10-14-2015 11:32 PM
