Replacing Shift Knob
Old 08-20-2012 | 07:41 PM
tilley's Avatar
tilley is infamous around these parts
Replacing Shift ****
Has anyone done this? Any tips on how to get the old one off and the new one on?
Old 08-24-2012 | 08:44 AM
RAKLAW's Avatar
RAKLAW has a spectacular aura aboutRAKLAW has a spectacular aura about
I purchased the Exclusive Aluminum shifter from Suncoast for my 13CTT.
My delaer instlled in in like 15 minutes. There is special tool used to remove it to prevent the release button from engaging.
I did not ever consider doing it myself
Old 04-13-2013 | 10:29 AM
JCBH's Avatar
JCBH is a splendid one to beholdJCBH is a splendid one to beholdJCBH is a splendid one to beholdJCBH is a splendid one to beholdJCBH is a splendid one to beholdJCBH is a splendid one to beholdJCBH is a splendid one to behold
I just got a new 2013 CTT - and was considering the Exclusive Shift ****...how do you like it compared to the original?
Old 04-13-2013 | 11:09 AM
RAKLAW's Avatar
When you get the Exclusive you wonder why Porsche did not make it standard (do we hear option $$$)
Anyway it is far superior...it's more robust and fits the fist grip...the aluminum base and trim compliment the shift plate...and it's looks so much better.
If you get one feel the difference in weight between the OEM pos and the exclusive.
I opted for it over the OEM carbon shifter, as the CF shifter is just the OEM with a little strip of cf
Old 04-13-2013 | 11:12 AM
JCBH's Avatar
Thanks! Think I will order it...seems really cool.
Old 04-13-2013 | 12:06 PM
gnat's Avatar
gnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant future
I pulled mine off and broke it. Then got my Tech to show me how to do it properly.
1) Twist the bottom of the shift **** to unlock it. I used one of those rubber strap wrenches, but my Tech could do it with his hand.
2) Pull the shifter button outward (towards the PCM). Again my Tech could use his fingers, but a thin tool to get behind and pull it forward might be helpful.
3) The **** should then lift free (with the button still pulled out) with no significant resistance. If there is resistance, go back to #1 and try again.
To reinstall it's the opposite (pull the button out, slide the **** on, release the button, and turn the lock at the bottom).
Since you are replacing your shifter anyway, I suggest practicing with it a few times to make sure you got it. Then the worst case is you just take it to the dealer to have them pop the new one on. Even if the button bit breaks like mine did, it's still drivable by pulling up on the white plastic bit that gets exposed when the **** is off (I suggest using the aluminum rod bit to do the actual shifting).
Old 04-13-2013 | 12:08 PM
Fkim011's Avatar
Fkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant future
GNAT- that is exactly right.
It takes 5 seconds to swap this thing out. Just a little twist of the silver base lock and it comes out.
Old 04-13-2013 | 12:53 PM
gnat's Avatar
Just to be clear, pulling the button out is critical. If you don't the **** will still come off, but the tab on the button that engages the selector will break and the button no longer functions.
Old 04-13-2013 | 08:03 PM
TGED's Avatar
TGED is infamous around these parts
The new shift **** seems quite wide, is it not blocking the view of some of the buttons?
Old 04-13-2013 | 09:35 PM
nash's Avatar
nash is infamous around these parts
Definitely go for the upgraded shifter. It looks really big in pictures, but in person the size is just right (get your mind out of the gutter). It really should be the standard issue.
Old 06-23-2014 | 03:30 PM
JoseCarlosC's Avatar
JoseCarlosC has a spectacular aura aboutJoseCarlosC has a spectacular aura about
do you guys think that the pdk shift **** would fit? i really like how it looks.
orbelo
08-30-2015 12:26 PM
ECS Tuning - VW
08-26-2015 12:13 PM
ECS Tuning - VW
08-19-2015 08:58 AM
Quick Reply: Replacing Shift Knob
