Spacer Q (Promise I've Searched) w/ 21" Turbo Wheels
Old 09-09-2013, 01:18 PM
robbys3m3's Avatar
robbys3m3 is infamous around these parts
Originally Posted by DrVolkl
Ok, again, only spacers on the rear... here are the shots:
Help at all?
looks great! if im doing my math right is that a 20mm spacer? if so, that makes me feel great about adding more than my 7 for the rear.
  #32
Old 09-09-2013, 01:27 PM
DrVolkl's Avatar
DrVolkl has a brilliant futureDrVolkl has a brilliant futureDrVolkl has a brilliant futureDrVolkl has a brilliant futureDrVolkl has a brilliant futureDrVolkl has a brilliant futureDrVolkl has a brilliant futureDrVolkl has a brilliant futureDrVolkl has a brilliant futureDrVolkl has a brilliant futureDrVolkl has a brilliant future
Yeah, the don't stick out at all.. brings them pretty flush. Not sure why they didn't do anything to the fronts... but it looks fairly flush all the way around.
  #33
Old 09-25-2013, 08:59 AM
modifier's Avatar
modifier is infamous around these parts
I bought some 7mm front and 15mm rear from Suncoast with longer lug bolts. Now I just need the GTS to put them on.
  #34
Old 09-25-2013, 12:32 PM
robbys3m3's Avatar
that should look great...after seeing the thicker rears im going to move to 14s in the back when my supplier gets them back in stock soon.
  #35
Old 09-26-2013, 07:34 PM
TTCarrera's Avatar
TTCarrera is a glorious beacon of lightTTCarrera is a glorious beacon of lightTTCarrera is a glorious beacon of lightTTCarrera is a glorious beacon of lightTTCarrera is a glorious beacon of lightTTCarrera is a glorious beacon of light
I thought I remember that the GTS has a different suspension geometry (same as Turbo) than the S and the wheels are already spaced out. Partly due to having the fender extensions.
No?
  #36
Old 09-26-2013, 08:32 PM
modifier's Avatar
GTS is lower than Turbo. Not sure about Turbo S. Fender extensions is an option that came with the 21 inch wheels option.
  #37
Old 11-13-2013, 09:49 AM
robbys3m3's Avatar
I bit the bullet and installed 14's on the rear last night...overall im happier with the look with 7's in front and 14's in the rear. for my gts and it's current alignment, im barely inside the fender extension on the driver's side and flush on the passenger's side. ill try to post pics tonight.
  #38
Old 11-13-2013, 01:15 PM
TTCarrera's Avatar
Originally Posted by PianoProdigy
I bought spacers from http://www.maxspeed-motorsports.com/spacerbolts.html
PACKAGE #13 2 x 7mm + 2 X 18mm SPACERS WITH BOLTS PRICE $289.95 USD
I forget which size went where. This was on 21" Turbo 2 wheels on 958 Turbo but the stance was great.
Agree. 7mm in Front and 18mm in Rear.
  #39
Old 11-14-2013, 02:05 PM
robbys3m3's Avatar
here are my pics..7mm in front and now 14 in the rear...slight variance side to side based on how camber may have been set...thx
ID:	301021   Click image for larger version
ID:	301022   Click image for larger version
ID:	301023   Click image for larger version
  #40
Old 02-06-2014, 04:28 PM
ACar's Avatar
ACar is infamous around these parts
RobbyS3M3, are those H&R spacers? I have a set of H&R 7mm + 14mm spacers from my 997 that I want to put on my 958. I like to know if I need longer bolts for the 958 as the stock bolts are 5mm longer. What bolt lengths (with 7mm and with 14mm) do I need. Also, are the size of the bolts (M14x1.5) and the bolt seats same for both Cayenne and 958. thx..
  #41
Old 02-06-2014, 05:28 PM
DrVolkl's Avatar
Where are you guys getting the 7mm fronts from? I'd like to do that to mine...
PS anyone want to trade their red/green GTS for my black one?! lol
  #42
Old 02-06-2014, 05:37 PM
HOiYA's Avatar
HOiYA is infamous around these parts
I see them available at Suncoast.
  #43
Old 02-06-2014, 05:45 PM
DrVolkl's Avatar
Ordered!
I'm not sure why they only put the large ones on the back of mine... this should fill things out better.
Now, again, anyone want to trade their red/green cayenne for mine?
  #44
Old 02-06-2014, 08:26 PM
robbys3m3's Avatar
I apologize but I'm not sure of the bolt lengths. I ordered everything from maxspeed motorsports, and they sent me the corresponding bolts, but i don't see the bolt length on the invoice, fwiw, these spacers seem very similar and of the same quality as the h&r's...I'm running those on both my black series and the gtr...sorry I'm not more help but I'm sure maxspeed or suncoast can get everything squared away.
  #45
Old 02-10-2014, 09:33 AM
7F/14R looks like a winner with 21" wheels and wider fender arches.
#TeamAIM
Quick Reply: Spacer Q (Promise I've Searched) w/ 21" Turbo Wheels
