Steering feels loose all of a sudden
Old 11-17-2013 | 10:13 PM
Jimmianne's Avatar
Jimmianne is infamous around these parts
I have about 7,000 miles on my 2013 Cayenne. When I drove it yesterday it felt different, as though the steering wheel was less connected to the tires. It did everything I asked but I didn't feel as confident as usual in the turns.
I'm calling the dealership in the morning but would like to hear thoughts from you guys before I explain the situation to the dealer.
Any thoughts?
Old 11-18-2013 | 10:45 AM
galion's Avatar
galion has much to be proud ofgalion has much to be proud ofgalion has much to be proud ofgalion has much to be proud ofgalion has much to be proud ofgalion has much to be proud ofgalion has much to be proud ofgalion has much to be proud ofgalion has much to be proud ofgalion has much to be proud of
Tire pressure?
Old 11-18-2013 | 11:17 AM
Jimmianne's Avatar
Originally Posted by galion
Tire pressure?
thanks.
I will check the psi's with the manual -both fronts & backs
have symmetrical numbers on the display.
Old 11-18-2013 | 12:15 PM
X5B4's Avatar
X5B4 is infamous around these parts
Do you have that easier steering option?
blanking on the specific option name at the moment....
Old 11-18-2013 | 01:54 PM
digitaljok's Avatar
digitaljok is infamous around these parts
The option is called servotronic, though blowing the fuse for that would make it heavier, not lighter.
Old 11-18-2013 | 02:04 PM
X5B4's Avatar
Actually, its called power steering plus in 2013 as we have it too.
It is obvious that loosing it might make steering heavier...
I googled the subject and a thread mentioned to check the power steering fluid levels...?
Old 11-18-2013 | 03:37 PM
dyim's Avatar
dyim is infamous around these parts
For the record, I assume you did not switch to winter tires. If pressure is the same, then it is unlikely to be tire issue.
Old 11-18-2013 | 04:56 PM
gnat's Avatar
gnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant future
Actually it's both. They changed it sometime during the year. It was Servotronic when I started to spec out a 2013 V6 (mid-late spring), but by the time I switched to my Diesel (July) it was PS+.
Old 11-18-2013 | 07:13 PM
Jimmianne's Avatar
It's all very mysterious - at least so far.
The yellow tire warning light came on. I drove around close to home for a while and the steering was very sloppy - then after about a mile it was back to normal [and at the same time the warning light went out].
[As I mentioned, tire pressure is good].
At least I feel more confident about driving 25 miles to the dealer for a check up.
If they come up with anything during a diagnostic I'll post it here.
Old 11-18-2013 | 10:50 PM
digitaljok's Avatar
Though servotronic / power steering plus have been ruled out already for your case, just for the record, pulling the fuse also does not throw any warning lights.
Old 11-19-2013 | 06:51 AM
Jimmianne's Avatar
FYI, the yellow tire warning light that came on said "not learning".
Do these cars have occasional computer glitches?
03EvoIII
09-21-2015 05:38 PM
Serg124
09-10-2015 06:24 AM
LiquidElephant
08-27-2015 07:17 PM
Zero911
08-24-2015 07:51 PM
thegrillboy
Cayenne 958
08-22-2015 10:24 AM
