BlueSpark Pro+Boost Gen2
#31
It will likely come preset to C5, so initially you can just plug and play. There's a little indentation in the horizontal panel to the right of the engine. Mine nestled in there and stays with a little help from Velcro. Excess cabling tucks away nicely beneath the panel.
If you like C5, you're good to go. I'm a little more adventuresome, and opened mine to try a few other settings. When I did so, I left the end cap off the box to facilitate moving the jumper selecting power settings. Plus - if you drop one of those little machine screws - you'll likely never see it again. I only put on about 700 miles a month, and try to avoid driving in the rain - so the box stayed dry the whole time. Pretty hard to get road water that high in the engine compartment anyway. I eventually ended up on E8 before reinstalling the end cap.
//greg//
//greg//
#32
Here is how I mounted it... at least temporarily until I find the setting I want to stick with. Hook up was super easy finding a suitable mounting place took much longer. I drove to the fuel station on C5 last night and honestly couldn't tell a difference from stock. I plan to step it up and find that extra torque and HP.
#33
Mine showed up today (they only told me it shipped Friday!). Their packing has greatly improved from the original Gen 1 packing materials. Sadly they still haven't updated the pictures to give a better description of where our boost sensor is
I'll get it tuned (probably going to go D or E, but need to read their docs and re-read Greg's info) and installed as soon as it stops raining.
#34
New 2014 CD
I have 1400 miles on my CD, just took it through the tail of the dragon at speed in sport suspension mode of course, actually handles quite well for such a large vehicle.
Ideally I would still like to do a proper chip tune on the 2014 CD but the code has not been cracked by Malone. Anyone know if Unitronic or RocketChip has cracked the code?
I may have to join the BlueSpark club.
Any plans to put your CD back on the dyno with the second Gen Bluespark?
#35
Mpg
My CD only has 1400 miles and has been filled twice.
Calculated mileage 25.9 on first tank and 26.8 on second take with a fair amount of spirited driving to break the motor in.
#36
Nope. I paid for the dyno results (which were suspect) on the Gen1 so it's someone else's turn to step up and dyno the Gen2 box.
#37
Number of BlueSpark Users
I have read posts from 3 different users who are running the BlueSpark Pro
what is the actual number of people using them?
Has anyone datalogged their boost curve with the blueSpark?
#41
The Gen2 box has its settings the other way around. The 0-9 of the old box is now the A-E of the red jumpers, whereas the blue potentiometer from the old box is now the 0-9 of the new (setting 5/6 is about centre from the old pot), so the old adjuster on 90% would be about setting 8 on the new dial.
The equivalent of Map 8 would be Map E.
Map 7 is Map D, Map 6 is C, Map 5 is B and Map 4 is A. These do not tally exactly as the maps have been modified for the US car but that is the general correlation.
#43
Got a response from them and since this doesn't seem to be spelled out this clear in this thread I figured I'd add it for anyone that started with the Gen1 threads and wants to compare apples to apple-like things I'm at C6 (how it came) and tried E6 and neither have done anything big for me. So I'll go out here in a bit and try a different setting with the new info.
Sorry for my confusion, but what does the round dial 0-9 do, so if I want old program 7 I need to move the red pin to D and dial...
#44
New: Jumpered header selects the basic map you want and the numbered dial lets you fine tune it.
Based on their information the translation is:
- No longer exists
- No longer exists
- No longer exists
- A
- B
- C
- D
- E
- No longer exists
So based on what you're asking (old map 7) and what they've provided, D (on the header) would be the setting you want. You'll then have to play with the dial to tweak it as you want.
Also keep in mind that since the Gen 2 is now tuned to the NA ECU saying "old map 7 = new map D" isn't factually correct. It's more of a general guide than a 1:1 translation.
#45
//greg//
