Made tail pipes black like a GTS
Old 05-14-2014, 07:48 PM
Harlequin NY's Avatar
Harlequin NY is a glorious beacon of lightHarlequin NY is a glorious beacon of lightHarlequin NY is a glorious beacon of lightHarlequin NY is a glorious beacon of lightHarlequin NY is a glorious beacon of lightHarlequin NY is a glorious beacon of light
Finally got around to doing the pipes black. I actually sprayed them on the car after masking everything off and they look good. I used the plastidip as other have discussed on here. I am very happy with the black look.
ID:	375056   Click image for larger version
Old 05-15-2014, 01:30 AM
salem55's Avatar
salem55 has a spectacular aura aboutsalem55 has a spectacular aura about
nice work, enjoy it
Old 05-15-2014, 05:52 AM
RAKLAW's Avatar
RAKLAW has a spectacular aura aboutRAKLAW has a spectacular aura about
Yup..goes very well with the entire color scheme of your car..
Now if only those calipers were yellow.. LOL
Old 05-15-2014, 08:14 AM
str8blst's Avatar
str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !
Looks great! Keep us posted on how the wear is with Plastic Dip.
Old 05-15-2014, 08:15 AM
I have the RAK stamp of approval
Yeah I know...............should have gotten the brakes. Next time for sure...
Old 05-15-2014, 08:22 AM
ECS Tuning - Porsche's Avatar
Those came out great! Nice work Harlequin.
Old 05-15-2014, 08:37 AM
str8blst- will do. I don't think they get hot since it is like a decorative pipe over the actual tail pipe but we'll see. I know I was always going back and cleaning the black exhaust stuff off the originals so that will be reduced since I won't see it
Thanks ECS. It was certainly an easy job that anyone can do.
Old 05-15-2014, 09:42 AM
STG991's Avatar
STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !
Great idea. I actually just got them powder coated gloss black (they were already black) on my 14 GTS. Porsche does such a bad job on the black finish. They literally just use some cheap spray paint (see first picture).
I just saw a used 2014 GTS with less than 3K miles on a dealer lot and the cheap black paint was chipping off already. Unbelievable. At least he tips on the 958 are alot easier to remove than the previous 957 GTS. My powder coater removed the outer sleeve by drilling out the rivets to separate the pieces. I was picky and wanted both the exhaust and sleeve done. He reinstalled new rivets again after finishing. It's all good to 1000 plus degrees! Powder coating is the best finish you could use. It might be a little bit overkill for just exhaust tips, but I'm pretty big on all the little details.
ID:	375133   Click image for larger version
ID:	375323   Click image for larger version
ID:	375342   Click image for larger version
ID:	375343   Click image for larger version
Old 05-15-2014, 09:44 AM
STG991's Avatar
I finally got the pic of the finished ones in the above post
Old 05-15-2014, 09:55 AM
That is great. I now must admit that I tried to remove them but had no success and didn't know that the rivets would need to be drilled. At one point I wanted to send them to Powdercoat Mike on the forum and he was going to do them for me. I know that is a better way to go. Congratulations!
Old 05-15-2014, 11:24 AM
gnat's Avatar
gnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant future
Welcome to the slippery slope of modding
Those lower reflectors are standing out pretty good now....
Old 05-15-2014, 11:39 AM
Heyyyyyyyy. I like them ! (as is )
I actually wish there was a way to put some LEDs in there.
Old 05-15-2014, 12:52 PM
gnat's Avatar
Where there is a will, there is always a way.
Just don't forget to write up the DIY
Old 05-15-2014, 09:53 PM
ronan's Avatar
ronan has much to be proud ofronan has much to be proud ofronan has much to be proud ofronan has much to be proud ofronan has much to be proud ofronan has much to be proud ofronan has much to be proud ofronan has much to be proud of
Originally Posted by STG958
Great idea. I actually just got them powder coated gloss black (they were already black) on my 14 GTS. Porsche does such a bad job on the black finish. They literally just use some cheap spray paint. I just saw a used 2014 GTS with less than 3K miles on a dealer lot and the cheap black paint was chipping off already. Unbelievable. At least he tips on the 958 are alot easier to remove than the previous 957 GTS. My powder coater removed the outer sleeve by drilling out the rivets to separate the pieces. I was picky and wanted both the exhaust and sleeve done. He reinstalled new rivets again after finishing. It's all good to 1000 plus degrees! Powder coating is the best finish you could use. It might be a little bit overkill for just exhaust tips, but I'm pretty big on all the little details.
Love the powder coating, definitely better than plastic dip.
Old 05-16-2014, 08:34 AM
STG958.
I just saw the new pictures. You weren't kidding you did it all out and it looks amazing! Congrats.
Quick Reply: Made tail pipes black like a GTS
