GIAC Tune installed on my 2014 CTT
#31
I had bypass pipes and the EVOMS piggyback on my CTT. It made huge gains from my butt dyno, but I believe the GIAC would of been much better.
I had the EVOMS on my GT2 and it was a real flash not a piggyback, and it was huge enough gains to burn out the stock clutch within 500 miles of the tune.
Now with the S6, I got the GIAC tune. I can say that no mod ever has given me a bigger difference in power gains and by a large margin. From now on if I am doing a tune on a turbo'd car it will be GIAC.
#34
#36
I went with Emmanuele Design and others have gone with GIAC direct. Both are board sponsors here. Having a local guy is good to answer questions, but you also get that here. So it really comes down to personal choice.
#38
If you don't mind a trip to Plano, contact Larry at Porsche of Plano. He'll help you get it taken care of.
#39
I have 34k under regular warranty but then CPO thru Feb 2019...
#40
That would be a conversation I'd have with the dealer. It's not something I can answer on their behalf.
#41
We can help you get sorted with the GIAC tune as well. With our DIY video, you can have the DME removed from the car in less than 10 minutes. Since you're out of state, you also save a good bit on sales tax. Feel free to send me a PM and we'll get you sorted
#43
Yes Austin, I have the EVOMS in my 2011 Cayenne Turbo. The reason I got it was because the GIAC was not available yet. In fact a considerable amount of time elapsed from when the EVOMs unit was installed in my Cayenne until the GIAC became available. While Evoms does give a nice increase in power, it is not a smooth delivery of the power. I didn't realize how "rough" it was until I had a chance to drive one with the GIAC. IMHO there is no comparison. I've owned a few 997 Turbos with the GIAC tune and was extremely happy. Should have waited as the extra time GIAC put into developing there tune really is evident. I am about to order a 2015 and will have the GIAC & secondary cat bypass pipes installed before I pick it up. Fortunately I have a very mod friendly dealer.
#44
Add secondary cat bypass pipes. Really improves the sound. I know in my 997 Turbos, adding an exhaust is almost mandatory if adding the GIAC. The engine NEEDS to breathe better for engine health. Also the HP increase is a lot more with both tune & exhaust as opposed to tune alone. I don't know if this is true with the Cayenne Turbo. Austin, can you elaborate? Also is there a difference in hp between tune alone, tune & secondary cat bypass pipes & tune a new entire exhaust in the Cayenne?
#45
I'd be interested in knowing this as well. Currently deciding between a full exhaust (Akra Evo) and/or bypass pipes.
