Steering Wheel Vibrating/Shaking.....
Old 07-05-2017 | 03:21 PM
csufl's Avatar
csufl is infamous around these parts
Hi Guys,
Need some help here! I am having vibrating/shaking from my Cayenne steering wheel... Even on the smooth road, it happens on varies speed.... But not constantly, some times it does, sometimes it doesn't....I have already road forced the wheels/tires, but the problem still exists... Did not hit any potholes or ran over anything particular....Anybody experienced this or have any suggestions what to do?
Also, I can feel a thud/knock/crack feeling when turning the steering wheel at parking lot speed... This happened after performed an alignment at an ind. shop.... Any idea what is it?
TIA!
JT
Old 07-05-2017 | 08:47 PM
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
Wild *** guess since I'm not there.. probably something in the driveline was damaged or misaligned by the independent shop. I've found the local Porsche shop to be fairly competitive on alignment and wheel balancing, and the results have been good. They're used to dealing with the huge tires used on these things, and know how to get them right. At least mine is.
Old 07-06-2017 | 07:36 AM
wkearney99's Avatar
wkearney99 has a spectacular aura aboutwkearney99 has a spectacular aura about
What was wrong before that you took it in for an alignment?
There's lots of reasons for low speed noises when turning. Driveline, steering gear, suspension, any combination might be involved. There's various bushings for control arms, tie rod ends, ball joints, etc.
I'd go back to the independent and ask them to explain.
Old 10-10-2021 | 08:08 AM
ciaka's Avatar
Vibration can also be caused by engine mounts bad. 9n porsches many are fluid filled, which leaks out after few yrmears, causing vibration at low rpm. Just something to check.
CY00
06-17-2020 04:05 AM
caunyd
06-28-2014 09:43 PM
cam99
05-16-2011 07:59 PM
mjguflaw
11-07-2009 08:33 PM
Quick Reply: Steering Wheel Vibrating/Shaking.....
