Cayenne - Softronics Tune + Bolt-ons - Results ~ 726 hp / 808 tq
@ Renn. man, I still havent figured out multi quoting, lol!
There are no liners in the Cayenne blocks!!! They are straight Alusil!
I will try to dig up the docs on the Aisin trans. I know that what makes the difference in the capacity based upon which vehicle the trans go's into is the clutch pack and how many friction plates are used. The CTT is of course the highest power vehicle that trans ever went into and I would assume gets the most friction plates. Instead of trying to guess at what will break in the trans. my plan is to just try to limit torque to around 800 and build a lot more top end power and see what breaks first. Looks like I'm going to be doing at least a dual 3" exhaust:-)
Have you looked into an air-oil separator or catch can setup? You might pick up a bit of timing and some power by getting that oil out of the intake charge. That mist is a mess and really induces detonation.
Ha! No worries. Take a look at this, it might help you out:
Really? I guess that answers that. I know that some guys over in Russia were putting in Iron sleeves, instead of the http://en.wikipedia.org/wiki/Alusil.
Sounds like a good plan to me. Send over the documentation if you run across it again.
Thanks for the hat tip. Considering these results, it is a no brainer - especially at these power levels.
Good idea - a secondary air-oil separator inline with the stock unit; maybe if you could work in some AN stainless braided lines too that would be awesome. I may or may not be one-step ahead of you on this one.. unconfirmed
You can get alusil liners, you can get alum. liners nikasil plated, and you can get reg iron liners. I chose to go iron because my builder had a lot of experience with it in the Cay. engine, cost, servicabiity, ring selection, and the Cay. block is a good candidate for sleeving to begin with.
Far as the A/O sep. go's
A. Not fair that you didn't list it in your mods;-)
B. What brand, are you happy with it?
C. Is it a catch can or a/o and if the latter where do you have the drain plumbed to?
It is a Mitsimoto baffled oil catch can with a threaded drain in case you wanted to turn it into an air/oil separator. I chose not to do the latter since I did not like the idea of welding into the oil pan in the Cayenne. The oil pan is hard to remove while on the vehicle and you introduce the possibility of warping the pan. So the easiest and most reliable option was to leave it as a catch can.
The design of this unit is pretty impressive; especially the fluid dynamics modelling
Yep.. from a couple of years go. She has quite a bit more power now though. Here is the link:
Video: Wicked Cayenne Turbo - Dyno[/QUOTE]
That sounds tough I love it. Good job
Hey Kent,
566 hp / 630 tq at the wheels is nothing but incredible for a 957 CTT. You have been my inspiration for the big build I have been doing and I'm sure you have led the way for many others who are modifying their Cayennes. The Cayenne community could not thank you enough.
I think you have reached the point where the stock turbos and stock intercoolers will be the limiting factors for you. Considering the amount of custom work you have done on your car, why not replace the intercooler with larger ones and achieve the real potential of the stock turbos? The ultimate step would be replacing the turbos together with the intercoolers and unleashing the real potential of the 957 CTT platform.
I have couple questions for you:
* Why did you go back to stock Bosh plugs? Any problem with the colder plugs?
* You have 2.75" piping from outlet of the intercoolers all the way to the throttle body including Y pipe. Why not also do the rest of the intake piping from cold air intake to the turbo inlet and from turbo outlet to intercooler inlet?
* Ditch those stock intercoolers for some large size efficient ones with Garrett air-to-air cores. Yeah, this was not a question.
Subscribed...
Subscribed...
However, if I wanted to push the stock turbos further, I would have to redo the plumbing from the turbo to the the bottom of the intercoolers and also increase the volume of air the intercoolers can handle. To do the latter, I would have to replace the stock intercoolers with larger units.
I am currently considering getting a set of intercooler cores and fabricating a new set of intercoolers from scratch. I just hate TIG welding aluminum
I am tempting to go and run larger piping to the other end of the intercoolers to the turbos, however, the intercoolers themselves would be the bottleneck in that scenario. So ideally, I would have larger intercoolers, then run larger piping.
Ha! Okay..something to think about I guess. I still think the methanol helps with the IATs. The main reason to swap intercoolers for me would be to decrease any flow bottlenecks. FWIW, I am already over what these Mitsubishi TD04-18T turbochargers are known to output. I doubt there is much more to extract at this level.
From what I've read, I would agree the stock turbos would be the next limiting factor for when you decide to go to that "next level". Intercoolers would obviously follow with the turbo upgrades. Unless of course you want to get silly and start reducing the weight.
A few questions:
1. I read why the change back to the stock plugs, every tuner nearly insists you go "one step colder" so would you say this is an unnecessary expense? I'm due to change the plugs on mine soon which is why I ask (I'm doing plenum, cai, tune, bypass pipes atm)
2. Tranny cooler - obviously for longevity/durability, was this something custom or is it an out-of-the-box item? DIY'er mod or not so much?
3. Would you recommend a similar build for a 955? particularly the plenum and intake manifold?
It's too bad there's not a huge following like with the cheap DSM's (Talon/Eclipse) or the Evo's that have specific tranny shops building and beefing transmissions up.
A few questions:
After loads of research and careful consideration, I am coming back from my modding-retirement on this platform in order to fabricate my own set of intercoolers. The main reason is for additional flow. By opening up the just less than 2" inlet/outlets on the factory intercooler, I should be able to increase engine response.
The Garrett air-to-air intercoolers are good, but they size their cores for primarily horizontal front mount applications. They have very few options for vertical side mount applications. So when all was said and done, I went with ETS cores since they seem to be able hold their own against the current OEM standard in the 911 world, the 997.2/GT2RS intercoolers.
A few questions:
You also need to keep in mind that methanol lowers the internal combustion temp range by about 150 -200 F degs, so I can get by with hotter plugs while running methanol.
https://www.6speedonline.com/forums/...oler-pics.html
Agreed. I am sure if you just wanted to throw money at it, you could get it sorted. Just not convinced it is worth the time and money right now.
Yeah..okay. So maybe I budged just a little under pressure
Next in the list should be replacing the Turbos..
