2013 Cayenne Turbo, High beams instead of turn signal
Hello,
I am new here! I noticed an issue after getting my car cleaned last week. When using turn signals, high beams activate instead of the turn signals. My hazard lights still work, so I know its not the bulbs. Did anyone have this issue? Any thoughts on how do I fix it?
Crumbled wires inside the light housings causing short circuits across different bulbs. Also there is a replaceable short harness outside the light housings which goes bad as well. I repaired my lighs internal wiring with marine grade shrink wrap, fine ever since.
WATCH THESE YOU TUBE videos : DIY Dan Headlight Repairs:
external patch harness;
Inside the housing repair; and,
Replacing the headlight ballast with an inexpensive aftermarket unit.
Good luck,
Brian C.
Good luck,
Brian C.
jamesporsche
Cayenne 958
12-03-2018 08:13 AM
