Cayenne Turbo All Cayenne Turbo model topics
04 turbo Catalytic converter
Old 08-08-2021 | 10:13 AM
Cheebs's Avatar
Cheebs is infamous around these parts
I have code p0421. The PO showed me the receipt for the replacement of the 02 sensor. But I did not see which one bank one or two. I assume both were replaced. So I am think the cat is the issue. What are my options to replace the cats? 1000 to 1200 per side sux for Oem when a high flow set is only a few hundred more.
Old 08-10-2021 | 11:37 AM
Cheebs's Avatar
Originally Posted by Fabspeed Motorsport
Throw some 200cel HJS cats on there and kiss your worries goodbye! Shoot me a Pm and I will be happy to discount a set for you
https://www.fabspeed.com/porsche-955...ic-converters/
I might consider this if the price is right. But I can’t find where to send a pm. I only see vm.
Old 09-27-2021 | 10:57 AM
BrianC72gt's Avatar
BrianC72gt is infamous around these parts
Check your PCV & check valve as well. If they are torn, your oil consumption will be pretty high. This excessive mist of oil makes the CATs' job that much harder too. Relatively cheap and easy to check. Swapped mine out and went from a quart every 1,500-2k miles to 5k+ and no oil consumption.
Madmap
04-14-2019 08:17 PM
PianoProdigy
Cayenne 955/957
11-22-2012 11:14 PM
bendicks1
02-03-2011 09:08 PM
BLKM3
07-16-2008 09:59 PM
cfi_luz
05-09-2008 02:08 PM
Quick Reply: 04 turbo Catalytic converter
