Add a trailer hitch
you gonna have to modify your rear bumper. Let me know what you come up with because i want to install one on my GTS also
I think it's about $1700-2000 installed at the dealer. If you don't need the wiring harness than you can get an afftermarket hitch for $150.
ya it's pricey, lus the aftermarket hitches won't hold the load of a factory installed hitch. Check into the ratings to see if it's worth it.
If you're just trailing a flatbed or a bike bed, and NOT a 8000 lb boat, you will be fine, but as least check to see if it's what you want.
Also, the lower rear defuiser will need to be cut to fit a hitch..
I understand the rear bumper/diffuser needs to be trimmed but the cutout is supposedly already there and easy to do. I want to go OEM because of the wiring harness and led taillights can be a hassle otherwise.
I installed an aftermarket (Curt MFG) hitch and I used the factory wire loom. Total cost was about $850.00. I installed the hitch, trimmed the diffuser myself then bought the wire loom & computer from Sunset Porsche and took it to my local dealer for installation and programing.
Jace is correct the factor hitch is rated at 7700 lbs and the Curt MFG hitch is rated at 6600 lbs on the website but there was a sitcker on the hitch it self with a 6000 lb max load.
With the Curt MFG hitch I tow a 20' flat bed car trailer with all the toys (VW Thing and motorcycles over 5000 lbs) with out any problems.
Cheep LED trailer still cause !!!! with the factory wire loom on the 04-06
You are correct on the diffuser needing to be trimed......
I called Curt MFG and they e-mailed me a list of dealers in my area. There was a RV trailer parts store on the list close to me and I had them order it. It took about a week for them to get it.
It was less $$$ then these guys https://www.eurodrivegear.com/script...?idproduct=825
I paied $160.00 plus tax 18 months ago
We sell those:
http://www.ecustomhitch.com/store/pr...?productid=677
Installation instructions are included on the page. For live help, call 1-800-828-9876 EST and ask for Jeff. He's done several.
We sell those:
Thanks,
Evan
