Fabspeed bypass pipe issue.... As usual
Old 12-12-2012 | 09:31 AM
Rvca3112's Avatar
Rvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant future
Well I installed my bypass pipes last night and I love the added noise to my pepper. Now I was driving around seeing if I had the infamous rattle on the car while driving. Random noises here and there. Nothing substantial other than a random interior rattle that ill pinpoint at a later date. Now this morning I start the truck up and I get this AWFUL rattle. I blip the throttle real fast and it goes away. I go to look under the car to see if I can see anything and I have a exhaust leak. I think the cause to all of our problems is the slip fitting that porsche uses to connect the exhaust. It was cold enough that I could see the exhaust fumes coming from both ends of the slip fitting. They are there tight. I'm gonna look under the car later and see if anything needs any tightening. Just wanted to see if anyone had any solutions to this... It's kind of embarrassing.
Old 12-12-2012 | 11:15 AM
03EvoIII's Avatar
03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute
If you can see exhaust coming out of the connections then something is not quite right. Maybe the diameter of the bypasses don't match your cat-back portion. Sorry to hear about that.
Old 12-13-2012 | 08:34 AM
Fabspeed Motorsport's Avatar
Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !
Hi Rvca, sorry to hear about your issue and its not supposed to have any kind of rattle. The factory sleeve clamps that join the two pipes may not be tightened down fully or something is not lined up correctly. Our Pipes have hangers on them so it should keep them from moving around too much, so make sure nothing is rubbing on the metal hangers and the sleeve clamp is properly seated evenly on both pipes so it has a good seal. Its always recommended to check all hardware and connections after an exhaust upgrade, as things can move and loosen due to expansion and contraction of the new parts. I would get under the car and tighten the clamps down more and check all other connections to verify there is nothing loose. If you are still having an issue, give us a call directly or you can always add a little exhaust sealant around both pipe connections so the sleeve clamp really locks everything down and will help eliminate any kind of smoke coming from it.
Thanks,
Old 04-22-2013 | 05:54 AM
FattySmax's Avatar
FattySmax has a spectacular aura aboutFattySmax has a spectacular aura about
I want these pipes but everything I've been hearing about them kinda scares me off.
Old 05-12-2013 | 10:10 AM
2gofast's Avatar
2gofast is infamous around these parts
I love my by-pass pipes. Go for it!
Old 05-13-2013 | 09:19 AM
RPVantage's Avatar
RPVantage is a splendid one to beholdRPVantage is a splendid one to beholdRPVantage is a splendid one to beholdRPVantage is a splendid one to beholdRPVantage is a splendid one to beholdRPVantage is a splendid one to beholdRPVantage is a splendid one to behold
Yes, you should buy them. No problems here so far.(2k miles with them)
Old 05-13-2013 | 06:42 PM
ez1973's Avatar
ez1973 is infamous around these partsez1973 is infamous around these parts
Had mine for two years now - no problems whatsoever. Go for it!
Old 07-29-2013 | 08:34 PM
hks's Avatar
hks
hks is infamous around these parts
i have the exact same problem on my '13 gts
Old 07-30-2013 | 11:27 AM
Rvca3112's Avatar
Ended up going to fabspeed a months ago and getting them looked at. My hanger was too long so it was hitting the transmission brace. They shortened them and now it's ready to go. No vibration or anything. Added their rear exhaust tips, HOLY **** the truck is loud as anything now. Both worth while additions. Fabspeed = great products, customer service, and performance.
Old 07-30-2013 | 05:09 PM
Hi HKS, im sorry to hear about your issue and I will try to help you get it resolved. Feel free to PM me or give us a call so we can go over it and figure out an easy solution. Thanks to everyone using the Fabspeed products and for the kind words, you guys are the best.
Thanks,
Rguy
04-12-2020 11:11 PM
pwdrhound
09-13-2016 10:44 AM
jyupitt1
09-10-2015 08:31 PM
al3656
09-07-2015 06:35 PM
TurboDragon
09-04-2015 09:11 PM
Quick Reply: Fabspeed bypass pipe issue.... As usual
