Any such thing as a Cayenne "hack"
Old 02-02-2013 | 09:54 AM
mep1811's Avatar
mep1811 is infamous around these parts
My Cayenne is pretty much bone stock. I know in some cars, even though the option is not ordered, it is still incorporated in the car and might only need a switch.
Example Toyota FJ Cruiser A-Trac. All FJs have A-Trac if you pay for the option you get the switch. or you don't pay for the option and buy a 25.00 switch and get the expensive option.
I have the stock radio. It has a bluetooth option on the screen but no bluetooth function. I wonder if it is there and there is a hack to get it .
Anyone out there who can help /
Old 02-02-2013 | 10:27 AM
gnat's Avatar
gnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant future
Porsche has a long history of not wiring for things you didn't order (and sometimes for the things you did order...). I'm sure there might be a few minor things, but I wouldn't count on anything big.
For your BT it might be a simple update to your PCM that needs to happen, but those post production upgrades usually cost as much if not more than ordering it with the option.
Edit: I see from your other thread that we are talking about a 958. I thought all of them came with BT enabled. If you are seeing the option on the PCM then you should have it. I'd verify that with your dealer.
Old 02-02-2013 | 10:30 AM
mep1811's Avatar
Ok thanks .You never know. I have a BT visor mount that works just fine
Old 02-26-2013 | 02:59 PM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
+1... saves costs and weight. Even though the cost savings may not be passed on directly to consumers, both things are good and efficient.
Old 02-26-2013 | 03:53 PM
gnat's Avatar
It doesn't save enough weight to have any significant impact on something like a Cayenne. A GT3 that is preped for the track, sure. A big 6000lb beast, not so much.
As far as the cost, it actually tends to cost the MFGs more to have multiple different wiring harnesses rather than a one size fits all. The raw materials may cost a bit more, but you have the reduced cost of only needing one type of wiring loom and one set of wiring diagrams.
Old 04-22-2013 | 06:08 AM
FattySmax's Avatar
FattySmax has a spectacular aura aboutFattySmax has a spectacular aura about
True. I have a bunch of buttons on my 04 PCM that are good for nothing
PV=nRT.
09-09-2022 06:06 PM
su_maverick
09-08-2015 11:12 AM
Fester
09-08-2015 09:35 AM
k-lo
Cayenne 958
09-01-2015 04:51 AM
murox
Cayenne 958
08-30-2015 09:58 PM
Quick Reply: Any such thing as a Cayenne "hack"
