Jukebox 2013 GTS
Hi TGED,
Admittedly, I've only just now transferred a handful of albums/folders, so will need to check into this further, but I think I observed:
1) When playing MP3 off from the USB drive, I did see album art displayed, but
2) After copying the entire USB contents to the Jukebox drive, I did not see album art displayed.
For reference, my music is organized as follows and this is how I had it on the USB drive, as well:
\Artist\Album\tracks.mp3
And, I do not have album art embedded into my MP3 files, so artwork is stored as:
It could be that the Jukebox function doesn't handle external album art jpg files, but only handles embedded artwork. Of course, this is pure speculation on my part and I will have to do some further experimentation with this.
Regards,
Dan W.
2013 Cayenne
Regards,
Dan W.
2013 Cayenne
To be clear, when you say "tag your album art to each song" are you referring to an operation that is performed on the PCM in the vehicle or an operation to be done to your music on your computer before transferring it to the Jukebox?
Dan
Given the size of storage devices these days, this isn't really a major concern anymore, but is something I'd intentionally avoided doing when I first started into computer based music.
At home, I actually have all of my music archived as lossless FLAC files, then I auto-generate MP3 from that, so it's quite likely that I could also automate the embedding of the artwork.
Thanks again,
Dan
Yes, we have that on our Cayenne, but I haven't gotten to it yet! :-) too many other fun things to read about first.
Dan
Dan
If your car has Porsche Car Connect and when you plug in an iPod, BT AUX becomes unavailable on your iPhone, but if you plug in an USB flash drive, BT AUX is available. On my Panamera(no Porsche Car Connect) I leave an iPod always plugged in and sometimes I will use BT AUX to listen to Internet radio using my iPhone. Therefore I am switching to an USB flash drive on the Cayenne.
When you do an album search on an attached USB stick, the album art is also displayed along with the album name, but on the Jukebox only album names are displayed in album search.
Cayenne-S,
New user here, just took delivery of my 2013 Cayenne and came across this post in trying to figure out how to copy MP3's to the internal Jukebox.
I was able to finally figure it out, the key for me was that my 16GB USB SanDisk thumbdrive need to be formatted as FAT32, not NTFS. Once I reformatted the thumbdrive, the Cayenne was able to detect the USB drive and play music from it, which then enables the ability to copy the files and folders to the internal Jukebox harddrive.
Hope this helps!
Best Regards,
Dan W.
2013 Cayenne
Hope this helps!
Best Regards,
Dan W.
2013 Cayenne
Well, I figured it out...when I wasn't able to access the files, it was because I had dragged a folder (with music files within) onto my jump drive that I was trying to open in the car. On a hunch today I dragged the files themselves onto the jump drive (not in a folder), went back into the car, plugged it in and bingo, it worked!
I made the same mistake by copying whole folders into the USB stick. Now I create folders on the USB stick, and I copy songs directly from my metadata software mp3id into the USB folders and things have been ok so far.
Bmw M3 Guy
02-21-2018 09:29 AM
kahala997s
09-15-2015 05:15 PM
