Help! Changed starter on cayenne and now won’t start
So I just recently just changed my starter and after getting all put back together, the car just cranks and will not turn over and start. Did I miss something.
If it cranks it’s turning over. If it’s not turning over; I thought new starters came with a new solenoid. If you used the old solenoid look there first. To run the motor needs air, spark and fuel, check there isn’t a kill switch somewhere in the ignition circuit that prevents the engine from running normally when the hood is open or removed. Hopefully someone more knowledgeable than I will chime in.
Yotam Refael
Cayenne 955/957
07-29-2015 07:31 AM
Yotam Refael
07-27-2015 01:38 PM
