Detailer A vs Detailer B
Just curious ... were people comparing the cars in person or pictures of the cars? IMHO, that makes a big difference.
It actually has a much more appealing look over the likes of prime or polyseal actually. Of course Zymol will tell you different, just as Jeff Werkstatt will tell you to only use acrylic jett trigger on top of prime as opposed to numerous product of the same genre. Truth be told, longevity have never been compromised and our companies responsibility is to bring the paint to the highest standards possible using our thousands of hours of troubleshooting and comparisons unless requested a specific product line. I prefer a pre wax product to contain as little fillers and silicones as possible. If using pre wax glaze, IME Vintage has never looked better than sitting on top RMG, then again it didn't add all that much to the look of perfected black paint with RMG on top.
I know Zymol has a program where you can become a registered user or whatnot, but I feel anyone who limits themselves to one product line is cutting themselves and their clients short. There are hundreds of high quality long lasting, great looking products, and I pride myself on the amount of time I have spent with each one of them, of course it would have been much easier to just cut one of the respected companies a check and single myself out.
Looks are subjective, but I thought it was interesting none-the-less.
It actually has a much more appealing look over the likes of prime of polyseal actually. Of course Zymol will tell you different, just as Jeff Werkstatt will tell you to only use acrylic jett trigger on top of prime as opposed to numerous product of the same genre. Truth be told, longevity have never been compromised and our companies responsibility is to bring the paint to the highest standards possible using our thousands of hours of troubleshooting and comparisons unless requested a specific product line. I prefer a pre wax product to contain as little fillers and silicones as possible. If using pre wax glaze, IME Vintage has never looked better than sitting on top RMG, then again it didn't add all that much to the look of perfected black paint with RMG on top.
By the way, I didn't cut zymol a check to become a factory detailer. It was "earned". I was using zymol for about 6 years, prior to becoming a factory detailer, and spent a week with the owner learning and getting trained further about proper technique and application. Didn't cost me a penny; zymol felt they should invest into someone that cares about their product and has the passion and knowledge to educate other; as I'm doing here. Zymol is well aware I sell and use other products, but as of yet, I'm still involved with them. Guess that vouches for their principles, character, and vision.
If comparing apples to apples, it doesn't matter if someone uses a detail spray to maintain the wax. If a detail spray is used with a lower end zymol and a higher end zymol, then the results stay consistent. I don't know of many people that simply wash their cars and just dry. Most people apply some sort of detail spray anyway to remove water spots, rejuvenate the wax, or simply add some more depth and shine. After spending hours, sometimes days, waxing with zymol, you would be wise to protect things for months by simply applying a detail spray.
On your waxing experience, have you used zymol vintage? If so, please explain how it was used (your technique), what the external environment was (indoors/outdoors, ambient temp, paint temp), and how you maintained it (weekly washes, drying, detail spray, etc.) Product list that you used would be helpful as well.
Add boosters to the product to keep it going is not fair. If you use Zaino, for example, and boost it with Z8 after washes, you will have an infinite protection length, because Z8 will bead water for 6-8 weeks on its own. As long as you wash every 6-8 weeks, you will never see a degredation in the quality of the product.
How long have you seen Vintage go, on its own? I have seen it last over 17 months on a car kept in a climate controlled garage, but again, this was likely the silicone base of HD-Cleanse vs. the actual carnauba content of the wax. One daily drivers, I have seen it skirt off at the one month point many times. The fact is, to maintain the look, the product must constantly be upkept, because standing alone, it doesn't have durability.
Do I speak with chemists often? Yes, did I know you were a Zymol factory detailer, No. Sorry if I hurt your feelings, that was not my intentions.
Also expertise once again "IMO" has nothing to do with longevity, McDonalds has been in business for fifty some years, and everything they make is pretty nasty "IMO".
I have never broke down the molecules of any product, or made claims that certain products contain certain ingredients on this thread, so I think I am in the clear.
HD-Cleanse is manfacutred by Meguiars and is very similar to #7, with several key changes including silicone structure and scent. I know you will ask for names, so I will drop them. Mike Phillips, Mike Pennington, and Scott Kennedy have all confirmed this.
You are correct, HD-Cleanse is required to get the "look" I suppose. The look you get is Vintage over HD-Cleanse. I personally prefer the "look" of Vintage of ClearKote RMG, but that is opinion and subjective of course.
I personally find HD-Cleanse very easy to work with, but the problems that people have polishing over it are documented by many high end detailers world wide, including Paul Dalton. Infact I find HD-Clease about as easy to use and Meguiars #7, which is no suprise.
It seems like you are saying your opinion counts because of your experience, but then you go on about how Brian isn't a chemist and make it sound like his experience doesn't. It is either egotistical on your part, or you have just contradicted yourself and said your opinion isn't valid. I'm not sure of the direction you where attempting to go with those posts?
Interesting to read this after reading the comment you just posted.
![Confused](https://www.6speedonline.com/forums/images/smilies/confused.gif)
Your sources are the main detailers that work for Meguiar's Corporate. Do you actually have a data sheet that states zymol HD-Cleanse has silicones in it and is made by Meguiar's? If so, please post it here. If you don't, I suggest you refract your "claims" and post "facts". Paul Dalton was using Zymol for years and promoted zymol's quality. Suddenly now, when zymol chose to end their relationship with Paul, zymol is no longer the same product he believed in and sold his clients onto ![Confused](https://www.6speedonline.com/forums/images/smilies/confused.gif)
Paul actually uses Roayle still; at least that's what he's told me over the phone and emailed as well. Once again, please get your facts straight and not mislead others.
If it's durability, then synthetics. End of story. When we developed our synthetic DyNA Brilliance paint sealant, it took us literally 8 months to get a synthetic to have the non-sterile and deep look of carnauba without sacrificing significant durability. In my neck of the woods, NY, a carnauba on a daily driven car wouldn't even last a month; and that's pushing it.
Here are some pics of a car finished with a synthetic sealant.
You seem to make a lot of claims and I have not seen you retract any statements thus far. Infact, what I have seen, is you try to discredit people for having a different opinion because they don't have facts or are not chemists in one post, while claming your opinions are valid because of your experience (even though you are not a chemist yourself).
I do not feel I have mislead others. What I feel is misleading is posting that Zymol will give you 6-8 months of durablity, with out mentioning the upkeep necessary to achieve these results. As Brian Brice mentioned, this is very similar to dealer applied sealants that will last 5 years (with reapplication every 6 months in small print).
ModBargains
Ferrari Vendor Classifieds
10-13-2015 03:47 PM
ModBargains
Lamborghini Vendor Classifieds
10-13-2015 03:47 PM
ModBargains
Maserati Vendor Classifieds
10-13-2015 03:46 PM
ModBargains
BMW Vendor Classifieds
10-13-2015 03:46 PM
ModBargains
Audi Vendor Classifieds
10-13-2015 03:45 PM
