Moe need help: Karcher K 3.68 assembly
At your recommendation got the Karcher today. Looks great but I can't assembly it , maybe some parts are missing from the package ?
Here is what I got and what I've managed to assembly.
Need your help asap. Are there any other parts needed ? The germans sent me only what I have in the pictures below.
I don't find any solution to fit those wheels Me
No installation instructions provided from the manufacturer , only safety stuff.
Did some progress , but still something is wrong , here are some closeups
The silver bar from the upper pics was put through a tube and connects the two wheels , but as you can see in the pics upper , it has only one end , the one below
to connect the wheels on the other side of the bar I've put one of the two plastic pieces
I got left now these two
one is a hoose connector but whats with the one on the left ?
Hi Dan. I've never used that pressure washer system; but I mentioned, it was a good one for the DIY. Here's a link on the installation manual I found http://www.karcherresidential.com/en/manuals.php Hope it helps
Already have that , however , I've managed to assembly it ... all I got left was this piece below
Do you have any ideea where it should go ? There were two pieces like this but one of it I've used it to connect the wheels with that silver bar , because the silver bar only had one plastic cap mounted, the second one was missing I suppose, because in the manual it has some other form then this one.
Here is the original plastic cap from the end of the silver bar upper
and here is the other part that I've put to fix the wheels, its the same part like the first picture in this post ... but it looks funny, it shouldn't be like that
Here is how it should look , got the pic from the manual
the final unit
and the connectors
in the right hole I should connect the water hoose right ?
the final unit
and the connectors
well it seems the tiny part left is a spare part to lock the wheels. thats what Karcher told me. however, they did forget to put in the package the other plastic wheel cover , they said it was not included and it is not available to buy... i wonder why they present the pressure washer with one mounted if you can't buy it.
now I should order my snow foam & lance + shampoo. Too bad I can't place the order for them yet, my PayPal account is limited for over 10 days and they do nothing to lift this limitation so I can pay. I hate them
ModBargains.com
996 Turbo Vendor Classifieds
10-01-2015 11:48 AM
ECS Tuning - VW
09-29-2015 01:49 PM
panas001
09-27-2015 02:51 PM
ECS Tuning - VW
09-25-2015 08:05 AM
