I feel like an idiot, Burnt my headlight
Welll... I was polishing my headlight with an orange pad and SIP, I didn't realize the very corner of the pad was dry, I put a burn in the light, Is there any hope or do I need to start sourcing a new Passenger side headlight?
I tried going at it with the SIP then 106FF, it made it look better, but nowhere near gone.
I assume you were using a PC?? I can't imagine using an orange pad with a rotary??
If you want quality advise, I would seriously post up some good pics, otherwise we have no real way to know what to tell you.
Could be not burnt at all, but the polish just fried to the surface which can be rubbed off.
Josh
Josh
I'll try to post up some pics tomorrow, it's definitely burnt, I took it from about 2.5" wide to 1.25" wide with the sip and 106ff, if you look closely there are small cracks in the plastic where it occurred.
Cracks in the plastic from burning???? That sounds strange, wouldn't it be more likely to melt or scuff??
Also, I don't understand what you're talking about when you say "I took it from about 2.5 wide to 1.25 wide with the sip"???
Sorry for all the questions, just trying to help.
Josh
Need more info.....
What machine you used?
Pictures...
Pictures...
I was using a mikita rotary at around 2500 rpm...
In reference to the size of it, I was able to make it smaller by buffing it with the SIP to a certain extent, the center of the mark appears to be deeper than the sides, pics to come.
YIKES!!!! A rotary at 2500...that's way too much. But the question I have is who recommended you using one? I'm sorry, but I've always preached DIY detailers keeping things in perspective and doing things within a comfort level. I can understand DIY detailers wanting to achieve results that are close to a professional, but there are times where the risk outweighs the rewards. I'm sorry to hear about the light, the most I've ever used the rotary is around 1500. The sweet spot is between 1200-1700 rpms but that's called the Danger Zone for a reason. I think whomever sold you this rotary should be partially responsible. If you were spinning that high then you probably did permanent damage and would have to replace a headlight. My 2 cents.
If the burn marks are on the surface there is a possibility that they could be sanded out. Still though, that is a major IF.
Like Moe said, 2500 is WAY too fast. There are times that I push around 1800, but that is only in very specific situations, and never for an extended duration. Remember that RPM and Heat have a direct correlation, and when you are working with a very small working space like a headlight you can't push those temperatures. If you were working with a very large area like a quarter of a hood or half of a door, then maybe you can push the temps a little bit as you are allowing the surface to cool by having a large working area, but definitely not with an area such as a headlight.
Pics will definitely help everyone to diagnose your issue though.
WOW< as said 2500 is WAY way to high. Most of the time mine is around 800-1500 max. To my knowledge none of the current polishes/compounds are rated for 2500rpm's.
Yea, changes are you totally melted the headlamp, you might be able to get a lens kit & clean it up a bit, but if you want it perfect, you will need a new headlight.
ahhh, I'm wrong about the RPM too... It was set between 2 and 3 on the makita, it goes up to 6 i believe and that is 3000rpm at 6. sooo... i guess it was more like 1200...
and, a couple high res. pics...
