help! holograms after waxing!
Old 06-10-2008 | 11:04 AM
detailjohn's Avatar
detailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to behold
it doesn't have anything to do with the respray on the car. I recommend you have the paintwork corrected properly, and reapply the wax.
John
Old 06-10-2008 | 11:45 AM
xxterxx's Avatar
xxterxx is infamous around these parts
just wondering...are u suppose to rewash the car after cleaner fluid?
or right after cleaner fluid just apply the wax...
i did the latter... a friend of mine tell me otherwise...washing after cleaner fluid is necessary..
Old 06-10-2008 | 08:09 PM
JoshVette's Avatar
JoshVette is infamous around these parts
I'm still a little uncertain as to what exactly is wrong, but you should be having perfect paint then only after waxing have swirls that weren't there before??
I would have it repolished again, sounds like the last guy didn't do it right.
Josh
Old 06-10-2008 | 10:58 PM
Stealth 993's Avatar
Stealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond repute
Did you use to much wax & not take it all off? Or did you have any silicone products on the car?
I would wash the car, then redo the cleaner fluid, then rewax, only use a very little bit, like the size of a half dollar will do the whole car & then some.
Old 06-11-2008 | 12:08 AM
Grouse's Avatar
Grouse is infamous around these parts
a litteral quote from stealth while helping him on his c4s.
That's like enough for eleventyseventybillion cars, or one c4s.
Old 06-11-2008 | 02:40 AM
xxterxx's Avatar
ok problem solved!
brought it to swissvax detailer....
its not because of the wax..its actually overapplication of cleaner fluid...
the cleaner fluid creates minor streaks that looks exactly like hairline scratches.... and the oil residue from CF got mixed up with the oil residue from the wax creates hologram and hazing that cannot be removed with QD whatsoever...only CF
my detailer even showed me the difference between concorso and mystery , he applied 2 waxes on 2 doors side by side.... mystery is definetely worth the money! omg..chocolate smell
Old 06-11-2008 | 06:03 PM
Atlas's Avatar
Atlas is infamous around these parts
Originally Posted by xxterxx
ok problem solved!
Well at the pace your going through the concorso you"ll need a new jar soon! Might as well pick up the Mystery
JK- glad you got it worked out and the wax is ok.
Old 06-11-2008 | 07:07 PM
xxterxx's Avatar
yeah...seems like its user failuer after all...
he divided the bonnet into half... one i did it... one he did it..
the one i did streaks all over...haze all over..
the one the dealer did...is glossy and shiny as hell...
Old 06-12-2008 | 04:21 AM
Atlas's Avatar
I use the red foam pad Phil carries at DD and use about the size of a peanut for the Swissvax cleaner fluid to do an entire door or panel or 1/2 of the hood. I apply the wax with the same type of pad very, very lightly misted with distilled water. I put a small amount of wax on the pad after warming it with my hands and apply a very thin coat, should be hard to see from three feet away, if that gives you an idea of how thin it is. I do the entire car this way if it's in a garage or shade and reasonable temp/humidity. You may have to go panel by panel if it sets up to fast after 10 min wait? I have 3 coats of Concorso on and the tub looks barely used. Never had any streaking, hazing or difficulty taking it off. Still beading and looking great after 3 weeks, 2 car washes, outside at work in 90+ degree days and 3 horrible rain storms.
Think of applying the cleaner or wax like putting suntan oil on a girl. Use a little bit and a light touch, rubbing it in lightly and feeling the paint/skin under your hand, almost as if you were massaging it in, to get good, even coverage. You are not trying to push it in or remove anything(that comes later if you did a good job on the skin, err paint I mean)
Bmw M3 Guy
02-21-2018 09:29 AM
Polar993
09-28-2015 11:15 AM
kaptaingus
09-27-2015 05:17 PM
Etahgnimusnoc
Detailing
09-25-2015 05:59 AM
JSF721
Detailing
09-08-2015 07:57 AM
Quick Reply: help! holograms after waxing!
