good leather cleaner
Thanks for the heads up! Will Make sure the web links work in the Signature.
I too have to vouch for the AutoGylm and Treat combo.
I did a direct comparison between the woolite solution and Autoglym, and although the woolite works excellent as a cleaner, it does leave a slight soapy residue on the surface. The autoglym was just as effective without leaving any residual substances behind.
Treat is a very good leather conditioner, it isn't a heavy conditioner so it can be used fairly regularly. If you need to do some deep conditioning then I recommend Leatherique. I have used it with fantastic results, but it is a product to be used infrequently. With the time it takes for it to be applied and sit in order to work well, it is something you only want to do maybe once or twice a year.
It takes leather that's hard and dirty and makes it clean and soft as a baby's bottom !
I haven't tried many of the cleaners conditioners mentioned in this thread but I will say that I've always had good luck with Lexol. Frankly I get pretty good results out of the woolite/water as a cleaner and some normal hand lotion for conditioning...
Try this:
Leather Master Kit
Cleaner - Conditioner - protectant
Matte finish and superior quality product.
Leather Master Kit
Leaves the seats feeling pure & clean, it's hard to describe.
I have not tried the gloss-it stuff yet, but I fell Leathermasters will be hard to beat.
The best cleaner I've found, and haven't switched from in 13 years, is Autoglym Interior Cleaner/Shampoo. It's an amazing product from England and it's a true multi-purpose leather cleaner, vinyl cleaner, plastic, carpets, etc. It leaves everything a satin finish and does not have soaps or harsh detergents.
Very impressed and happy with the results. My carpet color is linen (light gray) so marks and dirt show readily. Had a water stain there as well. After using the A I C the carpet looked close to new. That product turns a novice into a pro.
Glad you liked the product. It's been a life saver for me since 1997.
nick49
08-28-2015 01:40 PM
