CR Spotless De-Ionized Water System Group Buy
Back by popular demand, our CR Spotless Group Buy. Each time I try and give you guys a great deal that shows our appreciation for your support. As most of you know, the CR Spotless is the mobile DI system that actually works. Anywhere you don't want water spots and a crystal clean surface, CR Spotless is your tool of choice.
Here it is:
OFFER ENDS OCTOBER 11TH
DIC-20, Resin Refill, and Products Retail: $449.99 + $90.00 + $105.38....$645.37
5-10 units: $469.99 S+H included
10+ units: $449.99 S+H included
![](http://content.costco.com/Images/Content/ProductLarge/180790LL_v.jpg)
Product Description:
Hard water spots can destroy your vehicle's finish. That's why CR Spotless Water Systems created a de-ionizing system that takes out all of the minerals in your water so you can just WASH, RINSE, and WALK AWAY! That's right! With a DIC-20 Spotless Water System, you can let your car, RV, house windows, etc., air dry with no worries that hard water spots will appear. Say goodbye to towel drying and the scratches that towels and chamois can cause. You can even give your car a quick 5 minute rinse between washes to keep it looking great all the time.
Besides cars, de-ionized water is perfect for washing and SPOT-FREE rinsing of your:
Absolutely works. Can't live without it now. Also, get the Airmax dryer from Moe at Glistening Perfection. This two system process will eliminate drying, which will also cut down on the swirling potential from the hand drying. Highly recommended.
chardonet (6speedonline)
Grab a CR system from Moe - you won't be disappointed!
MidnighTT (6speedonline)
If you don't already have the CR system...you definitely need it...fantastic!!! I love mine!!!
TUUNER (6speedonline)
I also purchased a CRspotless, and some other products, from Moe some months ago. I got the same VIP treatment that you experienced. He's a pleasure to deal with. It's great to be able to speak with someone so knowledgeable and experienced. As far as the CRspotless, I concur, it works just as advertised. It's a great time and swirl mark saver.
Paladin (Rennlist)
I received the cr spotless from Moe on saturday. Used for the first time this afternoon. In a word...incredible.Even the windows are cleaner and require no wiping off after wash. Worth every penny. Moe was a pleasure to work with....had a delivery problem and Moe offered a free refill for my inconvenience. Even my wheels are shinier. I was doubtful at first but a friend if mine kept raving about it so I decided to try it. Im glad I did.
points (Rennlist)
Got mine today. Came home from C&C and it was sitting on my doorstep. Washed both cars in less time than I ususally spend on my 997 alone.
Well worth it!! Thanks Moe.
LeNoah (6speedonline)
Got mine last week and fired it up today in conjunction with a pressure washer for initial rinse and semi-final rinse and worked incredible. Just used an open hose for the last few seconds to "flood" and basically didn't really have to wipe anything down... Thanks again Moe
INSman (6speedonline)
Package Contents:
![](http://crspotless.com/images/magick_cache/pgroup_4_image_400x600__shadow.jpg)
![](http://crspotless.com/images/magick_cache/pgroup_15_image_400x600__shadow.jpg)
Input TDS Level Expected Yield (# of Gallons)
50 ppm............. 1600 gallons
100 ppm............. 800 gallons
200 ppm............. 400 gallons
400 ppm............. 200 gallons
Please PM or call 949-355-4911 if you have any questions. Add yourself to the list and PM me your info. We will contact you and take your order. Orders will ship once minimum of 10 units have been placed.
Here it is:
![](http://content.costco.com/Images/Content/ProductLarge/180790LL.jpg)
- Cars/trucks
- RVs
- Motorcycles
- Boats
- Golf Cars
- House Windows
- Patio Furniture
- Decks
Paladin (Rennlist)
points (Rennlist)
Package Contents:
- DIC-20 with in-line TDS Meter
- (2) 20" Cartridges Filled with De-Ionizing Resin
- 4' Inlet Hose (Attaches to Hose Bib)
- Nozzle (7 Pattern Garden Sprayer)
- Roll of Teflon Plumber's Tape
- Housing Wrench
- Quick Start Guide/Warranty Card
- einszett Perls Shampoo
- einszett Detail Spray
- 2 GP Australian Sheepskin Wash Mitts
- 6 GP MicroTowels
- 2 GP Drying Cloths
- Bonus: Glistening Perfection 11-Step Detail Guide ($10.00 value)
- A water de-ionization system, not a water softener
- Removes ALL minerals and dissolved solids from the water
- Battery operated, in-line TDS meter to monitor the water quality in and out of the system
- Ergonomically designed cart with a padded handle
- Easy to refill resin or replace cartridges when needed
- Seven pattern garden hose nozzle with FLAT setting
- 4' inlet hose to attach to hose spigot
- Produces 100% pure, mineral-free de-ionized water
- Pure water evaporates without leaving any spots behind
- Know when it's time to change or refill the cartridges before spots appear
- Take it anywhere; easily rolls and maneuvers with one hand
- No need to send it back for regeneration
- Flat spray pattern restricts water flow and increases pressure
- Everything is supplied even the car shampoo and mitts!
- Standard Garden Hose Bib
- Need to Restrict Water Flow to 4 Gallons Per Minute or Less with Supplied Nozzle on FLAT Pattern or Optional Pressure Washer
1. CWtwin
2. TXTurbo
3. Ruf-Racer
4. aaronchanfilms
5. Rec Racing
6. Ruf-Racer (2nd unit if we hit 10)
7. laj_c4s
8.
9.
10.
2. TXTurbo
3. Ruf-Racer
4. aaronchanfilms
5. Rec Racing
7. laj_c4s
8.
9.
10.
Hi Moe:
For those of us that already own the units, how about a group buy on the resin refills?? I hope there are enough of us here that purchased the CR units, and are now in need of the refills. Thanks for the consideration.
![hilarious](https://www.6speedonline.com/forums/images/smilies/smLach2.gif)
![Smilie](https://www.6speedonline.com/forums/images/smilies/smile.gif)
OK. Were down to the wire, 1 day left, and some of you may be on the fence. Here are some pictures of actual cars washed using the CR. As you can see, there are no waterspots anywhere:
![](http://www.glisteningperfection.com/WebForumPics/Products/DSCN5376-web.jpg)
![](http://www.glisteningperfection.com/WebForumPics/Products/DSCN5378-web.jpg)
![](http://www.glisteningperfection.com/WebForumPics/Products/DSCN5492-web.jpg)
![](http://www.glisteningperfection.com/WebForumPics/Products/DSCN5494-web.jpg)
![Thumbs up](https://www.6speedonline.com/forums/images/icons/icon14.gif)
I was able to get in on the group buy and got the CR unit as well as the heated blower. I used them this past weekend and WOW does this system work! Even here in Florida with sun issues etc, no spots whatsoever! Moe was great, he even called after hours on a Friday to give me the status of my order. The product is great and the customer service is fantastic! Thanks!!
i remember asking you about it a couple months back but still no other number showing up on the meter after a lot more use. can it be the electric pressure washer using less water
