help reconditioning oxidized/yellow headlights
The polycarbonate headlight lenses of my domestic suv have fogged over from oxidation. This appears to be a more and more prevalent problem with all makes of vehicles that spend a good amount of time outdoors in the sun, especially since almost all vehicle manufacturers use polycarbonate for the headlight covers for lighter weight and easier shaping. What seems to be the best long-term solution for removal of present and prevention of future oxidation?
I am aware of several solutions presented on the internet, chief among them being to wet sand the lenses with progressively finer grit sandpaper (1000, 1500, 2000, etc.) followed by polishing with a rubbing compound and finally the use of a clear coat or uv inhibiting coating. There are also products such as Meguiars PlastX, Novus, Plexus, Diamondite, Wolfgang, and then kits from Permatex, Crystal View, headlightsolution.net, which all seem to be packaged kits containing some abrasives, polishes and a coating/spray. There’s also some product called Pittman’s ALR, which is sold through ebay among other internet sites and claims to be an acrylic lens de-oxidizer.
Do any of these methods/products provide clearing of the yellowed headlight lenses for more than just a few weeks at a time before the lenses rehaze? There was a post in August of 2007 here on 6speed concerning yellowing lights with responses from MoeMistry and lechillo (I don’t know how to post links of previous posts), but other than the wet-sanding technique not too much else was presented. I’d like to find a more long-lasting solution before I just purchase new headlamps.
Thanks.
Thanks.
I know SEM (the company that makes spray paints) has come out with a system to repair the headlights which lasts. It also involves wetsanding and then spraying with a coating (without polishing) which is cured by UV light. The coating dries smooth (no orange peel) and lasts. I have not personally used it but my detailing buddy has in Florida on a Escalade and said it really works. I would recommend calling SEM and asking if they have any trained applicators in you area.
Matt
Matt
I've had good luck with simply wetsanding and polishing plastic lights. Depending on the state of the light I will start with either 1000 or 1500 and then move to 2000 grit. I often use automotive paint polish if I don't want to use a specific plastic polish.
DYL 911
04-19-2016 11:29 PM
ECS Tuning - BMW
09-29-2015 01:18 PM
