How to remove stains from clear bra . .
Just wanted to see if you guys had any method on removing stains off a clear bra. . the stains came from running over a some loose tire rubber and making black marks on the clear bra.
I have tried clay, alcohol. . nothing seems to work.
By stains, do you mean scuff? Sometimes there's rubber transferred to the paint or film as a result of impact. If that's the case, a mild polish should take care of it.
I got stains from rubber getting kicked up at track events and after each weekend I had to use a polish compound to get the black rubber streaks off. Then I would polish it all down with Novus Systems plastic polish.
