Wax at edges of Clearbra strips
Just finished waxing car with Mother's Synwax and have some residual wax at edges of clearbra strips. What is the best way to clear off the white wax residue from the edges of the plastic strips?
You can gently rub the edge of the film with a microfiber towel or wait til it dries and gently run a wooden toothpick along the edge. Be very careful not to expose the glue edge.
Something of note. When I wax around clearbra, I will generally mask off the line just a tiny bit over the edge with blue painter's tape. Then when you are done applying wax, you remove the tape and just wipe off the wax on the paint.
Pics might help.
D!
I just use some quick detailer and a microfiber. Are you sure it's wax and not the glue from the ClearBra? As the ClearBra gets warm, some of them will shrink a little and leave some residue around the edges. I usually remove that with a little adhesive remover on a microfiber. Just be sure to go back over any paint that you get the adhesive remover on with wax and to put some vinyl protectant on any clearbra you get the adhesive remover on. You need to rub really lightly and don't dig around the edges, but that should work.
Pics might help.
D!
Pics might help.
D!
You can lightly use a q-tip dipped in a little bit of isopropyl alcohol. This is what Venture Shield recommends. I will sometimes use a solvent based wax and a microfiber towel, seems to do the trick real well.
John
John
George
D!
Using a clean microfiber towel and quick detailer spray works well for us.
Premier Protective Films
ClearGuard Alpha PPF, Spectra PhotoSync Nano IR & CeraLuxe IRD Tint, Coatings
www.premiermobilegroup.com
Sharing our Passion on Youtube: https://urlgeni.us/youtube/Premier
Facebook: https://urlgeni.us/facebook/Premier
42630 Christy St, Fremont, CA. 510-623-1308 sales@premiermobilegroup.com
10-02-2015 02:23 PM
