Aluminum polish
Aluminum polish
I have some polished aluminum parts in my engine bay. Recently when washing it, if think there was some sort of reaction and the aluminum pieces came out hazy. These parts do not have a clear. Any ideas on the best method to polish the aluminum back to a brilliance back and with what product? Any help would be appreciated!
Brian
Brian
Brian
Brian
For engine parts you need something rather aggressive to start. I recommend "Sea Power" aluminum polish. It cuts very well, and has a lot of amonia in it which cleans as it polishes. If you really want it looking perfect, you can finish with something like "Metal" - You can get this from Moe. If you have staining you're going to spend a lot of time polishing if you start with something that isn't very aggressive. Start strong, and finish light.
John
John
Wenol. I used to polish sportbike frames and this stuff is by far the best.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
damon@tirerack.com
Or use this link:
I've used Flitz Aluminum Pre-Clean with good results. It gets the metal ready for whatever polish and sealant that you want to use. {Also available through Autopia }
Our Sonus Aluminum Restore followed by the Sonus Aluminum Polish and Sonus Aluminum Sealant works very well to restore uncoated aluminum.
Lynn
Lynn
If those don't work try "wet" sanding with a 1500 to 2000 grit sandpaper, then finish with a polish. I've been using mothers billet polish with success, never got around to trying anything different.
keeperofbeasts
11
04-03-2017 10:53 AM
ECS Tuning - VW
09-02-2015 01:19 PM
