cleaning/renewing black brake calipers
Callipers:
A way to spice up the look and at the same time protects the callipers from corrosion. The Calliper Paint System features aircraft quality paint, available in six different high gloss colours, Red, Yellow, Blue, Silver, Black, & Purple. The paint is heat resistant up to 925oF; this paint won't start running into your brake pads, it also seals and protects against corrosion.
Brake dust and dirt will not adhere to the calliper surface since adding the paint. The kit includes everything you'll need to get the job done, besides paint you'll also get reactor (special bonding agent), high tech calliper cleaner, mixing sticks, and a brush. Do not attempt to paint the rotor contact surface. G2-Performance Engineering Inc.
Cleaning
Ensure that the brake callipers are cool to the touch; never use a cleaner on callipers, wheels or brakes. Use a pH balanced cleaner just for an extra level of safety. Spray the calliper with d-limonene (citrus) based solvent (P21S Wheel Cleaner Gel) rinse off with clean water and then wipe it down with a soft wash mitt, sponge or micro fibre towel. Protect the face of the calliper with a traditional sealant similar to that used on your paint
Cleaning
An extract from one of a series of in-depth detailing articles © TOGWT ™ Ltd Copyright 2002-2008, all rights reserved.
some visuals, here is one we did recently. not on a porsche but brembo calipers in black.
https://www.6speedonline.com/forums/...s-ver-2-a.html
D!
ECS Tuning - VW
08-20-2015 04:07 PM
PelicanParts.com
08-18-2015 04:51 PM
